Hello. I have been having some issues with my pc as of recently.
Whenever i put my pc to sleep, instead of going into sleep mode my pc takes at least 10 mins to power off and doesn't wake up when i press any key on my keyboard or click my mouse.
It fully shuts down instead.
Also does the same thing when i click on shutdown.
Specs:
Windows version: Windows 10 , 10.0, build: 18363
Hardware: ASRock, Z97 Anniversary
CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
RAM: (32.0GB)
Also have Who-crashed info if that helps:
On Sat 1/25/2020 1:08:22 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012520-5375-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C14E0)
Bugcheck code: 0x9F (0x3, 0xFFFFE209C3176060, 0xFFFFF98AF88458B0, 0xFFFFE209C9BEFA60)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. A device object has been blocking an IRP for too long a time.
This is likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!MmTrimAllSystemPagableMemory+0x24477)
On Wed 1/22/2020 9:06:31 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012220-5046-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFA10F5C7B5820, 0xFFFFF8014D4CD8B0, 0xFFFFA10F60CCE980)
On Wed 1/22/2020 8:44:25 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012220-6390-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C8266)
Bugcheck code: 0x1000009F (0x4, 0x12C, 0xFFFFD38C5E5D6140, 0xFFFFD10B3347D8E0)
Error: CUSTOM_ERROR
On Wed 1/22/2020 8:31:30 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012220-7062-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFAF049BBFB9F0, 0xFFFFBF87FC07D8B0, 0xFFFFAF04A7113050)
Its been giving me a head ache and i am stumped on what to do.
Some help would be greatly appreciated. Thanks.
Specs:
RAM: (32.0GB)
Error: CUSTOM_ERROR
