Question drop Fps 2080 Q max/ i7-9750H CPU
Oct 4, 2023
5
I don't know what happened but all of a sudden I just have drop fps in all the games I've tried playing so far. I usually play CSGO2, Insurgency Sandstorm. My PC should be able to run all games but After a few minutes i have drop 20-30 fps After a few seconds it returns again 100+ FPS .
ROG Zephyrus S GX531GXR
Processor Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.59 GHz
Installed RAM 24.0 GB (23.9 GB usable)
Device ID 9E721244-7F8D-46C8-9C66-393B42DF03F5
Product ID 00325-81417-76768-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
RTX 2080 Q MAX
to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
Reset the BIOS by jumper clrCMOS or JBAT or similar (eventually you will have to set the boot priority correctly after that)
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
check the hard drive for errors with its manufacturer´s tool and if available, update the firmware
clean boot
