[SOLVED] Drop of Coolant on Mobo
Feb 5, 2020
27
So I was doing a leak test on my custom liquid cool setup. I covered the components beforehand, but a fitting was leaking and it was able to get touch the motherboard. It was a small drop on the bottom right corner. Haven't turned it on yet, but will this affect the motherboard?
That isn't a problem most are a mix of Glycol with additives but some of the cheaper versions can be Mineral oil or Distilled water. None of those are conductive and I am expecting you wiped it off quickly correct?
Yes, I cleaned it immediately. My coolant is the EK Cryofuel Solid Purple.
