DSL and Fax on same phone line
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
For four years I had no problem with using my Winfax
Prosoftware to send and receive faxes on the same phone
line with DSL. I recently purchased a new computer with
Windows XP. I immediately started having problems
receiving faxes. I bought a new fax filter, tried to use
Windows Fax, upgraded to a better modem, and still no
solution. I deleted the Winfax and re-installed it after
re-installing the Lucent winmodem. That worked for a
while, then the problem started again.
Also,
I received a Window update notice about the updating the
Lucent modem driver to an Agere modem driver. Hoping
this would be the solution, I downloaded the update, but
get the message that this driver has not passed windows
logo testing to verify compatibility with windows XP.
Please help.
The best advice is to attempt to use XP Fax only if you have a modem that is
listed on the Windows XP Hardware Compatibility List and using the latest
drivers.
Russ Valentine
[MVP-Outlook]
"Bill Burndrett" <anonymous@discussions.microsoft.com> wrote in message
news:278bb01c4638e$f2ac9900$a401280a@phx.gbl...
> Also,
> Please help.
Russ, the Lucent winmodem came with the computer. It was
listed on the Windows XP Hardware Compatibility List.
Windows update invited me to update the modem driver.
The Lucent driver update from Windows update is from
Agere, but the update is not listed. why would Windows
Update suppest an unapproved driver update?
Also, I don't like XP fax.
>-----Original Message-----
using the latest
>drivers.
>Russ Valentine
>[MVP-Outlook]
wrote in message
with
use
after
>> Also,
the
but
windows
>> Please help.
Well, I guess you're not missing anything after all, then.
I have yet to see a winmodem that works with XP Fax. Maybe someone else has.
Russ Valentine
[MVP-Outlook]
news:2810d01c46481$68871ae0$a601280a@phx.gbl...
> using the latest
> >drivers.
> >Russ Valentine
> >[MVP-Outlook]
> wrote in message
> with
> use
> after
> >> Also,
> the
> but
> windows
> >> Please help.
Not yet,but I try hard to avoid all modems! My Tablet has one, but it's
never been used.
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"Russ Valentine [MVP-Outlook]" <russval@mvps.org> wrote in message
news:Ok8CQTJZEHA.3128@TK2MSFTNGP09.phx.gbl...
> has.
> Russ Valentine
> [MVP-Outlook]
Russ Valentine [MVP-Outlook] wrote:
> *Well, I guess you're not missing anything after all, then.
> else has.
> Russ Valentine
> [MVP-Outlook]
> news:2810d01c46481$68871ae0$a601280a@phx.gbl...[vbcol=seagreen]
> > using the latest
> > wrote in message
> > with
> > use
> > after
> > the
> > but
> > windows *
sama
Posted via http://www.mcse.ms
View this thread: http://www.mcse.ms/message835821.html
My Lucent Winmodem works with no problems with my XP fax. Guess I'm
lucky...
"sama" <sama.1b3w07@mail.mcse.ms> wrote in message
news:sama.1b3w07@mail.mcse.ms...
> > else has.
> > Russ Valentine
> > [MVP-Outlook]
> > > using the latest
> > > wrote in message
> > > with
> > > use
> > > after
> > > the
> > > but
> > > windows *
> sama
