Nidhalof Prominent Dec 6, 2019 31 1 535 Jun 1, 2020 #1 I have 2 X 16GB of TeamGroup TED416G2400C1601 One of them is single channel and the other is dual but they are the exact same model, can i use them both on an msi z270 Sli Plus and hiw to plug them to get the full speed and efficiency ????
Solution rgd1101 Jun 1, 2020 if you already have them. plug them in and test it out. read the motherboard manual to see which 2 slot to use
rgd1101 Don't Moderator Nov 7, 2011 73,332 3,857 176,290 Jun 1, 2020 Solution #2 if you already have them. plug them in and test it out. read the motherboard manual to see which 2 slot to use Upvote 0 Downvote Solution
S SamirD Judicious Jan 16, 2014 6,610 956 35,940 Jun 1, 2020 #3 Modules don't come single and dual channel. If they're the same model number ddr3, you shouldn't have any issues. ddr4 may be more picky. Upvote 0 Downvote
