Dual channel help!
shikiramaru
65
Hello Tom's
i have a problem installing my RAM, my MOBO is Bio Star T5 XE CFX-SLI,
it supports up to 16gb RAM and it has 4 DIMM slot( also supports Dual channel ),, i have a 2X 8gb RAM,
so here it is,, the manual said ( i should put 1 8gb stick on A1 and B1 . or for 4x 4gb put it on A1-A2-B1-B2. )
but i have a Thermaltake Frio CPU Push and pull Cooler/heatsink.. its too big,,,
i can only put the RAM on A2+B1 or B2 the A1 is blocked by the fan of CPU cooler..
and now i put my RAM on B1+B2......i dont know if something bad would happen to my system,,,,
or what difference would it make? will it be slower? or faster? Risky? please help me,,,,
Thank You!!
I have the G-Skill Ripjaw 16gb RAM DDR 3 1333mhz
D
A2 + B2 should allow for dual channel operation. CPU-Z should tell you for sure.
D
Deleted member 217926
Guest
You can reinstall the CPU cooler. With most big air coolers you have to install the RAM then the cooler since the coolers overhang the slots. It should fit fine as long as the RAM goes in first.
You can just use B1 and B2 but you will lose the 4% - 5% gain from dual channel. It's a small loss but enough that I would reinstall the cooler myself.
shikiramaru
65
hi!!! I just did it..and it really can't fit,, i think the Frio is really huge or the RAM design is too big...it's like vengence/dominator...i think..
Is there any adapter i can buy to make the cooler float a lil bit more?
D
Guest
Are the heatspreaders actually too high and hit the bottom of the Frio or is it due to the motherboard design that the heatspreader hits the base of the Frio? I have never seen Ripjaws have a problem fitting in a well designed board.
Well after reading the mostly really bad reviews on that board it seems even a smallish air cooler lke the Hyper 212+ blocks RAM slots on it.
I think your only options are to either try RAM with no heatspreaders at all or live without having dual channel. 1.5v DDR3 does not need heatspreaders so that is not an issue but the price of new RAM might be. Samsung makes excellent memory without heatspreaders.
shikiramaru
65
yah you're right....overall,,,
how about putting the ram on A2+B2? is the performance the same as A1+B1? or it's just like B1+B2?
D
Guest
