Hi all,
I am putting together a gaming \ HTPC system with a TV screen for gaming\media and a computer monitor for office work, and am not quite sure about how components work together, here are some of the components:
CPU: Intel Core i5-2500K
Motherboard: Gigabyte GA-Z68X-UD3H-B3 (specification)
GPU: Gigabyte GTX570 (specification)
TV: Philips 40PFL8605 40" FullHD (specification)
PC monitor: yet to have it, let's assume a contemporary LCD display with standard connections.
Now, concerning video - I want to be able to view movies\games on the TV screen, and view the desktop and applications on the computer monitor at the same time.
Concerning audio - currently I want the audio to be played be TV, but in the future I may want to get a computer speaker system, and let the audio be played by it.
1. Can I simply connect both the TV and the computer monitor to the GPU's outputs? (the GPU has a mini HDMI output and a DVI-I ouput, the TV has an HDMI input and we can assume the monitor will have a DVI input) - can the GPU route the audio to the TV?
2. If that is the way to connect things - can I later make it so that the audio will not be played by the TV, rather by a computer speaker system?
3. If that is not the way to connect things (i.e. the GPU doesn't route audio) - I'm guessing the TV and computer monitor should not be connected to the GPU, rather to the motherboard (the motherboard has DVI-D and HDMI outputs). Is that how this should work? In that case - again - can I later make it so that the audio will be played back by a speaker system?
4. And something else - There will be a 15 feet distance between computer and TV, is there a quality-loss issue with HDMI cables over these distances? Also, mini-HDMI to HDMI conversion may be required, is there a quality-loss issue with this?
Please help me make some sense with all of this, thanks!
