[SOLVED] Dual fan (rgb?) air cooler suggestions.
sixstring88
114
so I am currently using a an AIO but I am not liking the performance or situation I am getting from it. I was wondering what are some suggestions for a dual fan air cooler with good performance. I also prefer RGB but if I can get better performance without it then its not a huge requirement.
Coolermaster MasterAir G100M or Scythe Mugen 5 ARGB Plus
The G100M is rgb, the Mugen 5 is argb. Make sure that you have the right lighting-header on your motherboard (you can buy an rgb controller from coolermaster for the G100M, which is controllable via usb)
Oh yea my bad I'll just list all of my current pc specs.
Ryzen 5 2600x
Asrock Steel Legend B450M
16gb XPG 3200 DDR4 ram
EVGA RTX 2060 KO Ultra gpu
Corsair CX750 psu
UpHere case fans x6 and hub
Deepcool Mattrexx 50 case
