Dual GTX 760 OC with Z87-Pro Question
tdslash
23
If I have dual 760's, which 2 expansion slots on the motherboard should I use to get the most out of the cards? I have never used dual cards before, so is an SLI bridge necessary? Thanks.
Hi there
For your system to run optimally, you will have to use a SLI bridge with your 760's.
You do not specify which mobo you have, but I am guessing that it has 2 x 16x slots, which is what you would use. They will run in 8x mode, but this is no matter.
Hi there
