Question Dual monitor arm recommendation?
11
Does anyone have recommendations for a monitor arm or monitor wall mount that fits what I’m wanting? I have one 32 inch monitor and wanting to get a 27 inch also, I have limited room, but do they make wall mounts or desk mounts where you can simply rotate the monitors to swamp their positions?
If you want the cream of the crop, there's the Ergotron LX single arm for $200. There is a dual monitor version, but it's $375 (and some versions go up to $450)
I use a Jarvis Single for my 32" monitor, it's cheaper at $140. For a dual monitor setup, it goes for $190.
If you want a cheap, bare bones one, there's this VIVO monitor arm for $30
None of these however will support swapping positions of the monitors, except may be the dual monitor Ergotron LX one if you position the arms just right.
