Question Dual monitor question
Aug 30, 2019
So my gaming headset broke and until i get a new one i need sound, but my new dell display doesnt have built in speakers. Is it possible that i use my old one and dual monitor it but use the second only for sound
What about the/any audio ports on the motherboard?
You may have other options.
Update your post to include full system hardware specs and OS.
For the most part, try what you can with what you have.
Do not download third party software or "fixes".
You can if the quality matters more than the sound coming from the correct monitor, just set up the other monitor and if Windows doesn't automatically send sound to it you right click the speaker in task bar, open sound settings and select it for your output.
