Dual monitor
brahmmaa
hello, I have purchased a DG 35 motherboard. i have one LG 700E CRT and one LG L224WS LCD monitor's both are VGA input's the mother board has two outputs one VGA and one dvi. i want to use dual monitor setup. i also have dvi to Vega converter i connected both monitors but the dvi to VGA via monitor haven't deduct any body can help me to solve this problem
If you have an Nvidia graphics card you have to go to the drivers (Nvidia Control panel).
In the Category Displays theres a sub category called Set up multiple displays, there you can choose what you want... I would suggest Dual view.
Hope I could help you... If you have a ati card google the problem you will find a solution
