dvd problems. Help, please!!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.video (More info?)
Hi! Ok, here's the deal. When I put a DVD in my dvd rom drive, it makes this
clicking noise like 3 or 4 times and then nothing happens. I have played
dvds in my computer before and it worked perfectly. I have tried everything.
I have uninstalled and then reinstalled my dvd software, I have checked to
see if I have a decoder and the system profile says that I have one and it is
found. I have done windows updates on my computer, I have upgraded my
windows media player and direct x. I have done all of this and nothing
helps. I am wondering if there is anything else I can do or if anyone knows
what the problem is. When i go to my computer and look in the drives, when a
dvd is in my computer it does not show that in the drive file. It seems to me
like maybe the drive isn't reading the dvd or something, but I don't know.
Anyway, I would really appreciate any help that anyone can give. Thanks so
much!
Is the click coming from the drive itself? If so it would point to a
physical problem and perhaps a faulty drive. Have you tried cleaning it?
Graham
Graham Hughes
MVP Digital Media
www.dvds2treasure.com
www.simplydv.com
"bucky1022" <bucky1022@discussions.microsoft.com> wrote in message
news:FE2C1AAF-E92D-4C72-B813-F084836FA306@microsoft.com...
this
everything.
is
knows
a
me
so
> much!
Ok, thank you so much for replying. But, how exactly do i go about cleaning
my drive? Thanks!
> Graham
> Graham Hughes
> MVP Digital Media
> www.simplydv.com
> this
> everything.
> is
> knows
> a
> me
> so
> > much!
Is it the bad disk ? Do other disks work ?
Rehan
www.rehanx.org - get more effects and transitions for movie maker
news:510F5F86-483F-4F31-81B6-E08B15EE180D@microsoft.com...
> cleaning
> my drive? Thanks!
>> Graham
>> Graham Hughes
>> MVP Digital Media
>> www.simplydv.com
>> > makes
>> this
>> > played
>> everything.
>> > to
>> > it
>> is
>> knows
>> > when
>> a
>> > to
>> me
>> > know.
>> > Thanks
>> so
>> > much!
No, i don't think so. I have tried 4 different dvds and none of them will
play, however, audio cds will work
> Rehan
> > cleaning
> > my drive? Thanks!
> >> Graham
> >> Graham Hughes
> >> MVP Digital Media
> >> www.simplydv.com
> >> > makes
> >> this
> >> > played
> >> everything.
> >> > to
> >> > it
> >> is
> >> knows
> >> > when
> >> a
> >> > to
> >> me
> >> > know.
> >> > Thanks
> >> so
> >> > much!
You can buy a dvd cleaning disc.
How old is the drive?
How much use has it had?
Where does the clicking come from?
Graham
Graham Hughes
MVP Digital Media
www.simplydv.com
cleaning
> my drive? Thanks!
> > Graham
> > Graham Hughes
> > MVP Digital Media
> > www.simplydv.com
makes
> > this
played
> > everything.
checked to
and it
> > is
nothing
> > knows
when
> > a
seems to
> > me
know.
Thanks
> > so
> > > much!
I am experiancing the same problem for a week now.
DVD Drive will read and burn cds but won't play dvd's.
Nothing wrong with the disk and i ve cleaned it with the
cleaning disk as well.But clicking noise only appears when
i try to play any DVD.
i ve re-insatlled the VGA driver made changes to color
depth and resolutions.Direct x seems to be working fine and
i m not recieving any conflicts reports.
Can anyone suggest something productive?
>-----Original Message-----
none of them will
>> Rehan
movie maker
in message
do i go about
>> > cleaning
>> > my drive? Thanks!
would point to a
tried cleaning it?
>> >> Graham
>> >> Graham Hughes
>> >> MVP Digital Media
>> >> www.simplydv.com
wrote in message
dvd rom drive, it
>> >> > makes
>> >> this
happens. I have
>> >> > played
I have tried
>> >> everything.
>> >> > to
that I have one and
>> >> > it
>> >> is
I have upgraded my
of this and nothing
can do or if anyone
>> >> knows
look in the drives,
>> >> > when
>> >> a
>> >> > to
>> >> me
>> >> > know.
anyone can give.
>> >> > Thanks
>> >> so
>> >> > much!
