E1200 Overclocking help
robmozza
4
BIOS 001 - http://i33.tinypic.com/ng9649.jpg
BIOS 002 - http://i38.tinypic.com/29xt7iv.jpg
BIOS 003 - http://i36.tinypic.com/24xdwyt.jpg
BIOS 004 - http://i38.tinypic.com/kb6skl.jpg
BIOS 005 - http://i33.tinypic.com/jpxvl1.jpg
BIOS 006 - http://i38.tinypic.com/akbacn.jpg
BIOS 007 - http://i37.tinypic.com/16b0ih0.jpg
My Computer - http://i36.tinypic.com/eivybd.jpg
Overclock - http://i38.tinypic.com/i3hso4.jpg
My Spec's
Biostar P4M890-M7 SE Motherboard
Intel E1200 Dual Core Celeron (1.6GHz)
1 x 1GB OCZ Gold PC2 5400 RAM (Temporary)
2 x 1GB Corsair XMS2 RAM (Coming in Post)
Nvidia 7600GS 512MB PCI-E Graphics Card
Win Power 650W Modular PSU
World Records - http://www.ripping.org/database.php?cpuid=670
OK, heres the problem! I've got a 'supposedly easy overclocking rig' but I'm only able to get it just over 2GHz
Please could somebody help me?
what kind of mobo is that i dont even think its compatible with that CPU?get a P35 mobo it will OC well.
that mobo is for all those old pentiums and the chipset is barely capable of having it on.
i know it says support it. but i dont think it will work in OC anyway since max support is 1066 and when it was first designed it wasnt designed for these high speed chip anyway. you need a new mobo definately!no doubt about it.
OK, thank-you, I do appreciate your help.
But, is there nothing more I can do with this current mobo to squeeze out some more MHz?
And what newer mobo would you suggest please?
You wont get much more out of a crappy motherboard like that. You will probably never get over 3.2 even though a few others have.
3.2 will be very capable on a P45 mbo like Asus P5Q pro.
