Several weeks ago I did a complete upgrade overhaul of my rig. However, I did keep the Core 2 Duo E6600 processor because it has performed very well since first buying it.
My old system would show the cpu idle at around 28C and depending on the game I was playing - around 35-38C under load. At the time I had an Evercool WC202 watercooling kit cooling my cpu. With my new system however, I chucked the Evercool (fed up with replacing water pumps) and purchased the Tuniq Tower 120 cpu cooler. With my new setup my idle cpu temp is around 28-31C and under load the temp balances around 39 -42C, not a huge difference, and it doesn't alarm me. I'm pretty sure these new temps are OK, but I am considering a small overclock and I know this will increase my cpu's temp.
I think the primary reason for the higher temps (as compared to my previous setup) is the Radeon HD 3870x2 graphic card. The card throws a good deal of heat, and I think the ambient temperature the card radiates has raised the internal temperature in my case. My question is; what are the E6600 Core 2 Duo cpu temperature thresholds under load? What temp should I be wary of at load with this cpu? Not sure if this extra info., is necessary, but here is a brief description of my system setup:
Abit IX38 QuadGT mobo, TT 650W QFan PSU, Mushkin Redline XP2-8000 DDR2 8GB ram, Radeon HD 3870x2 card, Tuniq Tower 120 cpu cooler, 3 TT 120mm cooling fans, Vista Home Premium Edition 64 bit SP1.
I'm really happy with this new setup as I have had no problems whatsoever. Everything runs fantastic - the gameplay with the new card is unbelievable. I just want to get a handle on any potential heat problems before I attempt to overclock my rig.
