I'm a step away from paying someone to help me
I've been reading through these forums and countless other articles for the past month trying to come up with the best computer I can afford, and I am still wary to buy a computer that may disappoint me in the end. So if anyone can please spare a minute to explain a few things, I would truly appreciate it.
I am trying to come up with the "sweet spot". I want to buy either the E6600 or possibly the E6700, and I want to OC it, but I want it stable with no problems. I will probably air cool the cpu using Thermaltake CL-P0310 120mm CPU Cooling Fan, unless someone can tell me a better fan that I should be using. I do not want to water cool it though.
I will also probably be using the EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard since I will be using a EVGA 768-P2-N837-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 KO HDCP Video Card. Unless you think another motherboard is better than that, and why please.
My main question is what kind of RAM should I be purchasing for either the overclocked E6600 or E6700? I was thinking about the CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory, 3-4-3-9, CAS 3 if I get the E6600, but I really have no clue what I should get. I guess the motherboard I was thinking about getting will let me overclock a locked processor without overclocking my memory. There is a feature/setting that you can put which allows you to UNLINK the Bus speed of your memory and the bus speed of your processor. You can then oc the processor with no affect to your memory.
So please tell me what the "sweet spot" is concerning which memory is best to buy for either E6600 or E6700 if I want the CPU's overclocked.
Thanks for any help. I'm doubtful I will get a response, but if I have to pay someone just to tell me what to buy, so be it.
Thank you!
Thank you!
