I noticed that my new build has been making a buzzing sound. It only occurs when starting a GPU intensive benchmark. Running prime95 has no issue. When running superposition or just playing a game, either my CPU or GPU block starts making a fairly loud buzzing noise. It start immediately after being stressed. It's very hard to tell whether its the CPU or GPU block but its one of them for sure.
I don't know how the blocks could make these noises, it really makes no since. It's not rattling like the pump speed is high and causing standoffs to rattle, its more like a phone vibrating on a table but faster. I don't feel any significant vibration however when touching the blocks.
Someone with near identical issue https://www.youtube.com/watch?v=rU7C-3YKyUY
They could not find the solution and he RMA'd the video card and it stopped. I can't RMA this $1,600 card because i've had it a year, so its not looking good for me.
The noise is the only issue ive had thus far and everything is working fine. Will I be safe using this card or is there going to be a problem?
Any ideas would be appreciated.
Edit: It seems like it could be coil wine, but this card never had issues until I installed the new custom loop.
PS - CPU - idle = 26c
load = 77c (Prime95)
GPU - idle = 26c
load = 54c (Superposition)
Res/Pump>GPU>CPU>Rad1>Rad2>
-EK-CoolStream SE 360 (Slim Triple)
-EK-CoolStream PE 360 (Triple)
-EK-XRES 140 Revo D5 RGB PWM (incl. sl. pump)
-EK-Supremacy EVO
-EK-FC1080 GTX Ti Aorus - Acetal+Nickel (rev. 2.0)
-EK-FC1080 GTX Ti Aorus Backplate - Black
-EK-DuraClear 11,1/15,9mm 3M RETAIL
-EK-ACF Fitting 12/16mm
-1080ti aorus
-8700k @4700
-32gb corsair vengeance @3200
-Asus maximus X formula
-2x 960 pro's
-Corsair HX850i PSU
-H700i NZXT
-Phanteks fan hub
-Hue+
GPU - idle = 26c
-EK-Supremacy EVO
-1080ti aorus
-8700k @4700
-2x 960 pro's
-Corsair HX850i PSU
-H700i NZXT
-Phanteks fan hub
-Hue+
