Error-Checking and defrag won't work Please Help!
Arcnite
37
Every time I try to run Error-checking on one of my drives it goes all the way to the end of phase 5 and then says "was unable to complete the disk check" I've ran it several times with the same result :( Any help out there?
Mobo: Epox 8K7A+
CPU: AMD Athlox XP2200+
OS: Windows XP pro SP1
HD: WD 80GB
HD: WD 180GB SE
RAM: 2x512MB DDR 2100
Toejam31
2,989
Which one of the disks ... the 180GB? And when you run the disk defragmenter, what kind of error message do you see, if any?
Does the problem occur in Safe Mode? Have you got a screen saver running, or some other TSR in the taskbar that might be interfering with the process?
How was the drive partitioned, and with what kind of program ... the WinXP CD, FDISK, a third-party program like Partition Magic, or with the WD Data Lifeguard Tools?
Is the system overclocked?
Toey
<A HREF="http://forums.btvillarin.com/index.php?act=ST&f=41&t=328&s=91c282f2e5207e99b7a652ee13b3512a" target="_new"><font color=green>My System Rigs</font color=green></A>
___________________________________________
<A HREF="http://forums.btvillarin.com/" target="_new"><b><font color=purple>BTVILLARIN.com</font color=purple></b></A> - <i><font color=orange>Your Computer Questions Answered</font color=orange></i>
Do you have an Anti-Virus program running in the background?
If so, disable it to run the program.
<b><font color=purple>Details, Details, Its all in the Details, If you need help, Don't leave out the Details.</font color=purple></b>
