Having just upgraded to an R9 290, my PC sounds like a jet, to the point where people behind walls are complaining. This won't do, so I'm going to to liquid cool the beast to reduce noise (and hopefully temperature.)
Now, I'm an idiot, engineer, genius, scientist, with a controversial dash of arrogance, so I decided to ignore common practice. Being poor, the loop will have the cheapest parts eBay has to offer (modified where necessary). Being mad, and this being my first liquid cooled setup, I've decided to go with ethanol instead of water. This means that in case of a leak, I don't have to worry about shorting, and if there's a very slow leak it'll evaporate with no problems.
I'm aware of the lower boiling point of ethanol, but if the temp gets to that anywhere in the loop, it'll mean bigger problems than just that. I'm also aware of the lower (about half) heat capacity of ethanol, and that's where I might run into problems. At worst, I'd be looking at double the DeltaT compared to water, but heat capacity isn't the only determinant of DeltaT.
I'll be using 2 240L/H pumps running in parallel to ensure redundancy in case of cheap components failing on me. 240L/H =~ 67ml/s, at least according to what's on the box. I'll be happy with 30mL from the parallel setup. Now, I'm planning on dumping around 300W through this system, so I'll have around 10J at most being transferred by each ml. If that were the only factor, that would give me around 3 degrees DeltaT with water and around 5 with ethanol. Not bad either way.
Ethanol also has about a quarter the thermal conductivity of water, but I'm hoping forced convection plays a much larger role in this sort of system than conduction does. With any luck I'll only see a few degrees of difference between what this system does and what it could do with water. Time will tell (eBay orders can take a month to arrive here).
2x 240L/H, 3m max head, water pumps running parallel for redundancy.
2x 40x40mm, $5 aluminium blocks for CPU & GPU, probably have to sand the bottom to get good contact.
200ml acrylic reservoir (easy to change if ethanol misbehaves with it chemically)
Silicone tubing, PVC fittings, other assorted junk.
120mm radiator (I know, I know. If it tests to be insufficient I have an old ATF cooler radiator lying about as backup).
Ethanol pros:
- No corrosion
- Non-conductive
- Quick evaporation
Cons:
- Low heat capacity
- Low conductivity
- Potential chemical interaction with acrylic components
I guess I'm posting this so you all can laugh at my naivete, and in hopes that someone might have experience with this sort of heresy and could give me a bit of advice or point out what I've missed.
Ethanol pros:
- No corrosion
- Non-conductive
- Quick evaporation
Cons:
- Low heat capacity
- Low conductivity
