As the title says, My ethernet link speed keeps changing to 100Mbps.
PC Specs:
Ryzen 7700x
Asus ROG STRIX B650-A GAMING WIFI
32Gb DDR5 Corsair Vengeance
RTX 2080
Network:
Virgin Media Hub 5
Netgear GS308
My network is as follows:
Router (1Gbps download) > around a 15 meter Cat6e Externally rated Ethernet > 8 Port Netgear GS308 Network switch > Cat 6e ethernet to main PC and work laptop (Plus other devices).
My PC motherboard has 10Gbps ethernet.
My work laptop which is tied into the same network switch with the exact same ethernet cable gets the full 1Gbps speed and doesn't keep changing , My PC only gets 100Mbps, well it caps itself at this speed. If I constantly keeping changing the port the ethernet is plugged into on the switch it get the full 1Gbps speed, If I then turn my PC off and back on it will cap at 100Mbps. I have changed the Speed&Duplex setting to 1Gbps, 2.5Gbps, Auto negotiate etc and no matter what it just keeps reverting back to 100Mbps. I have edited power plans and all the other settings but it goes back to 100Mbps.
No matter what I do it keeps reverting back so any help would be greatly appreciated.
PC Specs:
Ryzen 7700x
RTX 2080
Network:
Virgin Media Hub 5
Netgear GS308
