N Noah Burris Honorable Dec 30, 2013 5 0 10,510 Mar 14, 2014 #1 As the title suggests, I'm looking for the appropriate power supply. I used the ASUS calculator and it said that the minimum power supply would be 600w but should I used a 650, a 750 or something a bit lower in usage.
Solution killerswit2013 Mar 14, 2014 I used a 450 W PSu on gtx 780 card, now u can guess how much extra size PSU u are getting by comparing a 780 and 760. A 550 W PSu is good. Buy Seasonic G550 or some other good quality 550 W PSU. http://www.eggxpert.com/forums/thread/323050.aspx
Avocade Honorable Apr 12, 2013 1,002 0 11,460 Mar 14, 2014 #2 Get a 600W no need to stretch out that far. Unless your power lots of things. the GTX 760 isn't that power hungry. Upvote 0 Downvote
killerswit2013 Honorable Dec 19, 2013 146 0 10,760 Mar 14, 2014 Solution #3 I used a 450 W PSu on gtx 780 card, now u can guess how much extra size PSU u are getting by comparing a 780 and 760. A 550 W PSu is good. Buy Seasonic G550 or some other good quality 550 W PSU. http://www.eggxpert.com/forums/thread/323050.aspx Upvote 0 Downvote Solution
