Question Existing build won't POST, no error codes after previous start up problems ?
paulod
Commendable
Dec 29, 2022
22
Hi got an issue with my pc which has been intermittent but now appears permanent.
Problem began after pc was left in sleep mode and my wife decided to turn it off at the mains, following that it wouldn't boot and took 4 or 5 presses of the reset button before it would post. Once it started everything would work fine with no issues gaming etc and close down normally.
Next problem my wife (again 🙄) managed to somehow push the reset button into the case meaning the only way to power on / off when it didn't boot was to hold the power button in for a few seconds. This worked for a week or so (I should have bought a new case but was waiting till this weekend as I've been away) but now won't post at all, no beep codes or display
I've swapped memory slots and tried new RAM with no joy.
Tried onboard graphics still no display - ignore this as my cpu has no integrated graphics
Reset CMOS
Only post beep codes I get is when I completely remove memory or unplug power to graphics card.
My mind is pointing towards my power supply but any help much appreciated
PC Specs
Motherboard: ASRock B450M Fatal1ty K4
CPU: Ryzen 7 5700X3D
GPU: Radeon RX 6600
RAM: 2 x 8GB DDR4 CMK16GX4M2B3000C15 at 3000 and 2 x 16GB same RAM at 3200
SSD: Drevo X1 Pro
HDD: Seagate ST2000DM008
PSU: Corsair CV550
OS: Windows 11 Professional 64-bit
Next problem my wife (again ) managed to somehow push the reset button into the case meaning the only way to power on / off when it didn't boot was to hold the power button in for a few seconds.
You should've disconnected the reset switch for the case, wired to the motherboard's front panel header.
motherboard: asrock B450m fatal1ty K4
Rams should be populating slots A2 and B2.
cpu: ryzen 7 5700x3d
Your processor lacks an iGPU so no matter what display output port you hook up to the motherboard, you're not going to get a display out without a discrete GPU.
psu: Corsair CV550
You might want to source(borrow, not buy) a reliably built 650W PSU and see if you're able to get the system to fire up.
If your BIOS is what's corrupt on the motherboard, then you will need to source a CH341A BIOS programmer toolkit to help recover/reflash the BIOS. If that fails, you're in need of a new motherboard, if a reliably built PSU doesn't revive it. FYI, the CV unit is a horrible unit, rebadged VS unit.
If it is indeed the BIOS being corrupt, then it's a good investment to buy motherboard's that have BIOS recovery options(like Q-Flash Plus or BIOS FlashBack or Flash BIOS) so you can recover said BIOS without additional contraptions.
PSU is a good starting point but a no cost change would be to remove the reset button jumper from your motherboard front panel connector point, the place where the HDD, power button and reset are connected. This will negate the faulty button.
My assumption is that the button is being seen as pressed by the motherboard. If that doesn’t make a difference then look at changing components.
Thanks for the replies, I can borrow a psu from work tomorrow and give that a try.
Would the action of having the power switched off when in sleep mode potentially damage anything else?
Sorry I didn’t make it clear , the button has physically been pushed into the case but isn’t depressed if that makes sense
Update
I tried starting up today and CPU fan and video card fans no longer spin up on attempt to start.
Also, my USB keyboard and mouse are also not lighting up now, does this point to the PSU?
Try to isolate the problem.
Have you got a multimeter?
Check to see that the power supply is working. Connect the ATXconnector and the cpu power connectors to the motherboard. Connect the front panel switch. Remove the GPU, hard drives etc. make sure you know which drive is plugged in where.
https://www.etechnophiles.com/wp-content/uploads/2023/02/ATX-power-supply-connector-pinout-1.png
Power on the motherboard and using a multimeter verify that the voltages shown in the link above are seen.
Does your motherboard have indicator leds? Not all boards do and it’s a pain (Aorus b550 elite ax v2 I’m thinking of you here)
What do the lights show?
No lights on motherboard unfortunately
I’m looking to borrow a psu to check if that’s the issue. Will also try and find my multimeter and give that a try
Finally got around to checking the power supply and on the 24 pin connector everything is fine in terms of voltage.
Still no cpu fan or graphics card fan spin up on attempt to start so my thoughts now turn to maybe a motherboard issue.
Any thoughts
Thanks
Any thoughts
Thanks
the 3.3v, -12v, +5v, +12v are Ok? What is the voltage on PWR_OK with the power button both on and off?
I had taken the psu out the case to test it and all voltages were good.
Will I get different readings testing with it connected to motherboard?
Sorry if this is a daft question
Any thoughts
Thanks
What about the cpu power, separate 8 pin connector often on the top edge of the motherboard near the I/O backplate?
No joy.
Took a memory stick out and now no longer restarts, gpu fan is spinning but no display
Have you tried both sticks of RAM in slot A2 one at a time? The only other thing to try would be a new known good PSU. This will either show that your PSU is good or bad. If the problem persists then we know that the original PSU was not the issue. If the problems go away, we know that the PSU was the issue.
