8/31/2012 Thread Update Note: This is a repost of the original thread, this cooling was actually put into use in June of 2011.
As the title says, "Exploring Below Ambient Water Cooling", below is the cooling setup that was in use when this thread was first posted, the pictures are still here simply because it is a viable fully functional alternative cooling solution. This cooling solution has gone through many changes testing different ideas you will need to scroll into the thread, to discover those changes, as they reference what works and what doesn't.
Scrolling close to the end of the thread, to see the present setup using TEC (Peltier), assisted cooling eliminating the ice altogether, taking this cooling solution from high maintenance to literally zero maintenance. Use this information however you decide to apply it for your own needs and goals. This is definitely exploring below ambient cooling, enjoy the pictures and the read, and thanks for checking the thread out! Ryan
Link to TEC/Peltier CPU Water Cooling Thread
I have run traditional water cooling closed loops, but the traditional closed loop did not meet my cooling needs, I was looking for a cooling solution to use below ambient water temperatures, to handle the overclocking load temperatures I was reaching, it's given fact you can get more 24/7 overclock stability, the cooler you can keep the CPU.
Pictures can say a thousand words, and from the very beginning of this project there have been changes and modifications made to improve the performance, solve issues and problems, and being this is a below ambient water cooling solution it needs to start with a Caution.
Caution: Water temperatures down to 0c produce condensation, and if you intend going that low motherboard insulating precautions have to be taken.
You can safely operate approximately 8c below ambient room temperature, more than likely wherever you live without any condensation at all. That 8c below ambient is an extremely conservative number, as where I live it's 13c below ambient that I run. However that is totally dependent on the dew point level where you live, and you will have to test and discover how low you can safely run below ambient, without condensation, for yourself.
More regarding temperature and condensation below.
Also this is not a mobile solution, you will not be carrying this cooling solution to your local lan party, even though you could always tap into your buddies drink cooler. :lol: JKing
So speaking of cooler, even though the pump is the heart, the cooler is the reservoir in my situation holding 10 gallons of distilled water, leaving enough room to add if needed 2 2/3rd filled jugs of frozen distilled water, ICE blocks, to drop the water temperature to where I want it.
I'm using a Coleman cooler widely available even at Walmart, the model I am using and most Coleman end drain cooler models have the perfect size drain outlet to accept a barbed brass fitting, with nothing more than a hose clamp to secure it.
Feed Line Connection Close Up
The water return line had the be cut in so the lid could be closed and sealed, the wire you see in the picture is a temperature probe.
Return Line Close Up w Temp Probe Wire Entering Cooler
The heart of the system is a Swiftech MCP655 variable speed pump.
All the tubing is insulated.
Critter control by AC Pan Tabs, 2 tabs per gallon have worked nicely, no critters growing in the solution, no corrosive metal or plastic damage, these AC Pan Tabs are stocked at Home Depot or can be ordered online. Add the tablets 2 at a time allowing complete dissolving between additions until you've completed adding all you'll be using. Do not add all the tablets at one time! I also run 1 Silver killcoil inside the pump intake tubing, located as far away from the pump as possible.
Pan Tablets Package Close UP
The perfect filters for the Cooler Master drain which is the pump intake line are the Spectre high performance gas filter replacement cartridges pictured below, stocked at your local Autozone or also orderable online.
Filter Package Closeup
They are nylon mesh open end filters that you cap one end and the other end fits snugly into the drain opening.
I have since modified the filtering to allow longer run time between filter maintenance swap out and clean by mating two of the filters together and used JB Weld epoxy to do it.
Since you have to open the cooler to change out the ice blocks, dust in the air gets into the cooler, the filters trap any dust particulates, and keep them from entering the pump and water block, keeping the circulating part of the system clean.
Use whatever water block you like this is an XSPC Rasa and a Danger Den.
Temperature and Condensation:
Humidity levels where you live, will affect the operational water temperatures you can drop down to and safely run with condensation not a problem. You will have to do your own tests to discover what water temperature level, condensation begins to occur. When condensation begins to form, unless you take serious insulation precautions, you need to operate at temperatures above that point.
Directed airflow on the condensation producing elements inside the computer will evaporate the forming condensation allowing you to go below the condensation forming point to a certain extent, but eventually you will discover a lower temperature the fan won't stop the condensation.
Condensation begins to form for me at 8c water temperature that's 15c below ambient room temperature, that's some serious overclocking headroom., I usually operate around the 15c water temperature range, which is 8c below ambient. Over time you will learn what works good for you, whether surfing the net, benchmarking, gaming, etc., and how much ice you'll need to support the activity at the overclock you're running.
CPU Temperature Results:
These comparative tests below were run with my 2500K overclocked to 4500mhz @ 1.325v with one 580GTX at 23c ambient.
The 4 core temperatures were averaged together for one total score.
Air Cooling;
Noctua NH-D14, Idle = 32.75c, Load = 54.75c
Thermalright 120 Extreme 2 fans in push/pull, Idle = 32c, Load = 51.75c
Standard Water Cooling Closed Loop;
XSPC Rasa RS240 kit, Idle = 30.75c, Load = 50c
XSPC Rasa with a Black Ice 240 Radiator, Idle = 30.25c, Load = 48.75c
Ice Block Chilled Water cooling;
Water Temperature at 23c Ambient, Idle = 27.75c, Load = 46.5c
Water Temperature at 20c, No Condensation, Idle = 26c, Load = 43.5c
Water Temperature at 15c, No Condensation, Idle = 21.5c, Load = 37c
Water Temperature at 10c, No Condensation, Idle = 15c, Load = 34c
Water Temperature at 7c, Condensation Direct Fan Controlled, Idle = 13c, Load = 30.25c
Note Regarding CPU Water Blocks Used: I have tested 3 water blocks, Danger Den MC-TDX (Highest Flow Rate), Swiftech Apogee XT rev2, and XSPC Rasa, the Rasa Water Block, is the best performer temperature wise.
Thermal Mass:
I've wanted to address the subject of Thermal Mass because some here don't fully understand how this works in your favor with this cooling solution, some relating to slush box reference simply stuck a radiator in coolers or buckets with crushed or small formed ice. There are many examples of various types of slush boxes across the internet of tried projects, some even used dry ice and water, and of course it is a short lived solution because ice melts and dry ice evaporates. In the case of dry ice and methanol slush boxes sub zero temperatures are produced causing a host of problems to deal with way past condensation. I found it comical when one of the guys radiator actually froze, what water circulation did he have then. :lol:
Regarding my setup and thermal mass, I have 8 gallons of water inside an insulated cooler, I use the frozen jugs of water because they are a dependable constant variable, it takes time to cool down 8 solid gallons of water, it does not happen instantly, and in the reverse, it takes time to warm up 8 gallons of water. This is not a short time solution as far as water temperature is concerned even with 2500K overclocks to 5,000mhz and 5,100mhz, thermal mass allows those high clocks to be 24/7 rock solid stable, the only reason I do not run those clocks 24/7 is the voltage it takes to run them.
Without this cooling I could not run my 2500K at 5ghz for anything more than a CPU-Z validation, but this cooling allows not only reaching but acquiring stability once getting there. The thermal mass of the water ensures longevity of certain temperature levels that you may be needing to accomplish your overclocking goals successfully. Additionally for longevity the system is constantly running at cooler levels all the time, even if I allowed the water temperature to rise to ambient room temperature, it still bests a standard water cooling closed loop, it opens completely new doors of possibility.
If you have the end cooling results staring you in the face, the maintenance is a fair trade for the cooling gains. I know this cooling solution is not for everyone, it takes up space, it is a high maintenance solution, it takes a time investment, it is not portable or potable, you cannot drink the water, but if you do have the room for it and you ever try it for yourself, I'd love to know what you have to say then.
Air Cooling;
Thermal Mass:
