External hard drive not recognised by device manager, disk management or EaseUS Patrition Master. Need to wipe to return.
buttermere
Commendable
May 5, 2016
4
New hard drive broke down within a week of buying. I want to return it but I can't wipe it and it's full of my unencrypted personal data.
I'm using Windows 8.1 but it's not recognised on my Mac either.
Nothing recognises it. It powers on and I can feel the disks spinning.
Any ideas on how to wipe it so I can be 100% sure it's all gone? Will I need to resport to running a magnet over it, or will that not be guaranteed to wipe the data?
jason201
Upstanding
Feb 20, 2018
166
40
To be honest, if you're concerned about your data, you'll have to take an L here and physically destroy it!
You'd have to open it down to the platter level (from the sticker side), remove the platters, and scratch em hardcore with a utility knife (or drill dozens of holes in em) and dispose when done. You'd need a decent set of TORX screwdrivers (and possibly pliers) in order to do this.
USAFRet
If the drive is actually non-functional, you can't.
Running a magnet over the outside of the drive will do nothing.
Opening up the case to expose the platters will completely void your warranty.
buttermere
Commendable
May 5, 2016
4
Thanks everyone for your answers. I'm going to drill a dozen holes in it, can't be arsed with fiddling around with those small screws.
Similar threads
