Another thing that really grinds my gears(thank you Family Guy). Why do all these CPU/GPU heatsinks have these heatpipes? Whats the point? I never noticed such high temps. a few years back when if you wanted to overclock, you grabbed a quality beefy, cooper heatsink with a thin sorface and alot of fins. Or if you had to, a huge aluminum heatsink (aka. the Novatech Alpha).
The problem is, when you have such a confined area to work with, heat pipes simply do not work! And just look at that picture, the heat pipes are UPSIDE DOWN! In order for them to function, the MUST remain vertical. This is so the condensed fluid flows back down to the contact area. If they are upside down, the refrigerant just sits there. Besides that, Heatpipes ONLY WORK AT A CERTAIN TEMP. RANGE! What that means is that the CPU/GPU MUST climb to that temp before the refrigerant in the heat pipes start to evaporate.
So.. A think (1/8 inch) slab of copper with a large amount of fins creating a large surface/contact area is by far THE way to go. I'll be happy when all this heat pipe nonsense goes the way of the dodo!
/end rant.
