Extreme watercooling please help
If you are using a brass or nickel-plated barb and you threading it into a metal fitting, I would still use teflon tape, but as I always advise folks with TIM and thread tape, sparingly is the best policy. I think with most folks using thread tape, it becomes a problem because they overuse it (just like TIM). Like I said, one or 2 loops around the thread is sufficient for almost any fitting. Anything more, and you wost certainly will have a problem with cracking, or even have issue where the thread actually cuts the tape and then you have particles in your fluid.
here is the final list
Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump with speed controller
XSPC Reservoir Top for Laing DDC
2xFeser X-Changer 480mm Xtreme Performance Radiator - Thermochill Killers!(i can't find it in stock at frozencpu,jab-tec,sidewindercomputers or performance-pc :S:S any suggestion on where i could find it in stock ?
Swiftech Apogee™ GTZ SE Ultra High Finish Universal CPU Waterblock - Nickel Plated (LGA 1366 Ready!)
20xPrimoChill PrimoFlex PRO LRT Tubing 7/16"ID 5/8" OD with 3/32" Wall - UV Blue
20x Primochill Reusable Hose Clamp [16mm, 5/8" OD] - Black
16xScythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case Fan - Retail
3xSwiftech MCW60-R2 GPU Waterblock
3xSwiftech GTX 200 Mounting Hardware for MCW60-R/R2
i am really desperate on the fittings,i don't know what fits what so please help me
also thanks guys you are very helpful and friendly unlike the guys at Evga forum and the guys at the overclockers forum
This rad will do: http://www.jab-tech.com/Feser-X-Changer-Quad-120mm-Xtreme-Performance-Radiator-pr-4279.html
Feser X-Changer Quad 120mm
Overall, good set up. Don't forget to grab some PT Nuke or Kill Coils.
Coils: http://www.petrastechshop.com/sikibyia.html
PT Nuke: http://www.petrastechshop.com/peptpcobi1.html
As for fittings, what do you want to know? The GTZ will come with both 1/2in (what you will use) and 3/8 in fittings.
Note: 7/16 ID tubing will fit 1/2in barbs, but it's going to be a tight fit, so you will need to use a bit of force.
The R2 (see: http://www.petrastechshop.com/swmcgpuwawg81.html ) also comes with 1/2in and 3/8 fittings. And the Petra's one already ships with GT200 mounting so you won't have to buy it separately. (If not buying from Petras makesure the block comes/doesn't come with the GT200 mounting. If it comes wit it you won't need the mounting)
Note: You will need RAM sinks if using the R2.
thanks for the precious information,i checked jab-tech before they don't have it in stock it seems i will have to wait for any of sidewinder,froznecpu,jap-tech and performance-pcs to have them in stock also will this do the job with the R2 ?Swiftech MCW-Ramcool /A GeForce VGA Memory Water-block
^i found these ram sinks at newegg but i heard that it has some tape issues that it doesn't stick,so will the Arctic Silver Adhesive (Premium Silver Thermal Epoxy) - 7.0 Gram (ASTA-7G) do the job ?
Meh. I don't really have a preference. It's all about the same. Only difference is how much it's able to bend before kinking. In that respect, IIRC Tygon wins. (Can't be 100% sure, it's been a while since I checked about different tubings)
here is my final list
Sunbeam Rheobus Extreme - Black fan controller
2xArctic Silver Adhesive (Premium Silver Thermal Epoxy) - 7.0 Gram (ASTA-7G)
Innovation Cooling Diamond "24 Carat" Thermal Compound - 4.8 Grams
3xSwiftech MC14 Copper Heatsinks only - Retail(8 pieces each)
10xSilver KillCoils by iandh or 10xPetra'sTech PT_Nuke -PHN Concentrated Biocide (10mL)(which will perform better)
2 gallon of distilled water from a local shop
i will post some pictures after it is build but unfortunately there many parts tha i can't find in stock at newegg(not the watercooling parts)so i will try to get them from another place,i think unfortunately i will need some time to get all the parts :cry: :cry: :cry: :cry:
Mounting ramsinks on video cards isn't that hard. Most problems stem from not cleaning the ram. The thermal pads leave a film of silicon oil that won't come off with alcohol. You need goof off or my fav Artic Cleaner, a two bottle set. Sold at many PC online and earthbound stores like Frys.
I use Seksui (I think) thermal double sided sticky tape. Very very thin and one of the very best out there. It has never caused me any problems.
http://www.xtremesystems.org/forums/archive/index.php/t-109836.html
http://www.ocforums.com/showthread.php?t=544844
Dont let it take too long. If you do by then everything will change and you will just end doing something different.
Agreed! Epoxy is almost impossible to get off. On RAM :pfff: Are you nuts. RAM is too volatile for such things.....
