Question Extreme4 Z370 Won't POST and Can Flash Pink then Blue lights on MB
summiteagle
No POST. Often pink lights and then blue lights show on the ASRock Z390 Extreme4. The fans don't turn on.
As for some history, the first motherboard was replaced (RMA) by ASRock. Since then I have talked with ASRock Technical Support and the replacement motherboard they sent was successfully tested by them. I have reseated the RAM and reversed and re-reversed the POWER SW connector. I have made some changes with the fan connection locations. Suggestions?
i5-8500 CPU
Noctua NH-D9L CPU cooler
ASRock Z370 Extreme4 motherboard
Corsair Vengence LED 3000 2x8 RAM
Seasonic Gold Plus 550 PSU
EVGA 1050 2GB graphics card
NZXT H440 (w/fan hub)
