Looking for displays with a thin bezel design so i can use eyefinity/nvidia surround. Please give me a list of monitors that would fit into this category. thanks.
my second question is would 60hz vs 120hz for non 3d gaming be that different? thanks.
All depends on the person, some people see the difference, some don't
How good are your low-FPS tolerances, if you can go below 30-ish without caring, then 60 is enough for you, if you get your panties in a bunch when you dip below 50, 120hz is a good investment.
i am somewhere about 40 and above person. so i guess a 60hz should be fine. the question is about the bezel size and panel type
60hz monitors are fine, I run my triple display on 60hz monitors and have no problems with it
Toms ran an article a while ago about some new thin bezel monitors that Acer? i think was releasing, they are meant to have 2mm bezels, can't find it off hand though
