So, hardware I am running.
CPU - AMD 3600x Stock
GPU - Nvidia 1070
RAM - DDR4 Corsair 2x8GB at 3200mhz
Motherboard - MPG x570 Gaming Edge Wifi
Problem - I've never noticed this before when I started up my computer, I've noticed now that every single one of my Ez LED Bug lights to flash once and then all come on at once and it goes away, and my computer launches without a problem. I haven't downloaded anything that would mess with anyone of my components. As well as that, I've noticed that my fans stay on way longer than they use to when I turn off my PC so that's started to concern me as well.
Should I be concerned here? Do my LED lights mean that something is happening, or is it a process the launch of the computer goes through just to check if the parts are working right and it can go ahead and launch windows afterward, and I've just never noticed it.
GPU - Nvidia 1070
