[SOLVED] Fan 2 stays at 0 rpm under load.
Juszf7
In Precision and from irl observation only fan 1 spins under heavy load. (Like 100 percent benchmark load) It says "
Fan 2 0 RPM 52%" in precision and even when I add a custom fan curve it still stays at 0 RPM.
I think the fan is disconnected or broken. You can get replacement fans and they would have a replacement connector. Check if the fan is connected to the card first.
Oftentimes GPUs can actually run just fine with 1 fan for a long time just by spinning up the working fan a little faster.
