Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
On Sun, 09 May 2004 08:52:08 +0200, Patrick Cras
<patrick.cras*delete_this*@easynet.be> wrote:
>on 09-05-2004 00:20 We Live For The One We Die For The One said the following:
>> Your cards pluged into your PC thus ir has power and your Fan is
>> pluged into your card
work it out.
>And it has a power connection too. But I asked this because the fan made some
>garbling noise when my PC booted.
>I think I found the problem, there was a cable from the sound card, connected
>to the motherboard that has a label on it, and that was very close to the
>fan from the 9800 Pro.
>So I cut of that label.
>Patrick
just pick up a VGA silencer from artic cooling for about $20, they are
quiet and work awsome. they even cool the inside of the case as well
