I have a build I'm working on for my son. It's a Mini-ITX build in a Razer Tomahawk Mini case.
I have a Thermalright Phantom Spirit 120 SE that I want to use, however I'm curious how the airflow will work here and what the best option would be from a fan placement standpoint.
As you can see I currently have an exhaust fan on the case. From an airflow perspective, I'm wondering what fan placement I should use.
Option 1: Keep exhaust fan, fan in center, fan on right.
Option 2: Discard exhaust fan, fan in center, fan on right.
Option 3: Discard exhaust fan, fan on left, fan in center.
Option 4: Other ideas?
It essentially comes down to not knowing how efficient the exhaust fan/center fan synergy is, and not knowing if the center fan would be enough to exhaust on its own if the case fan is removed.
Or maybe I'm just overthinking it and option 1 is totally fine and I wouldn't have any problems.
