Fan connection question.
nodsterr
78
I am currently putting together my first build. The case i have is a N600 by cooler master(window version). I have five total fans to power. Im lost because im not sure where to plug in because there is only two 3-pin connectors and this power fan connector which i have no clue what that is for. please help me hook this rig up correctly.
Case is here...
http://www.coolermaster-usa.com/product.php?product_id=10067&product_name=N600
Motherboard i have is here...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157369
fan1: front intake fan is powered by a molex because it has an onboard speed controller for itself
fan2: top exhaust 3-pin
fan3: top exhaust 3-pin
fan4: rear exhaust 3-pin
fan5: fan that is on my evo 212 cooler which is a 4-pin
So, here are my motherboards connections...
2 x CPU Fan connectors (1 x 4-pin, 1 x 3-pin)
3 x Chassis Fan connectors (1 x 4-pin, 2 x 3-pin)
1 x Power Fan connector (3-pin)
Thanks
It would work - but from the description - I don't think it would throttle the speed of the fan. I you want it running at 100% - it would be fine. Hook it up, if it is too noisy - look into getting one of those adapters.
thanks for the feedback!
Also what is the 3-pin "PowerFanConnector"? and could i use that for the last rear exhaust fan.
Connecting the fans to the mobo allow you to control the speed via the mobo (BIOS and/or Software), so when heat builds up, the fans spin faster. Connecting anything to the PSU via molex will result in 100% speed all the time unless a controller is installed.
The "powerfanconnector" is a 100% on connector (you can use that as well), when you power on, it runs at 100%.
ok this is all making sense now,... one more question is could i connect that last 3-pin to the unused 3-pin cpu connector?
