Fan connections on Mobo
Control_tech
18
I have a Gigabyte GA-Z68X-UD3H-B3 and I have spots for 4 fan connections.
CPU fan 4 pin
Sytem fan 3 pin
System fan 4 pin
Power fan 3 pin
My question is what is the signifigance of using these connections and what if the counterpart (power supply) has a 4 pin connection.
A 4-pin fan header offers fan speed monitoring and PWM (Pulse Width Modulation) speed control as long as you're using a PWM controllable fan.
A 3-pin fan header offers fan speed monitoring only. The fan runs at full speed unless it has its own speed control potentiometer or step down resistors.
Fans plugged directly into a power supply connector has no fan speed monitoring and runs at full speed unless it has its own speed control potentiometer or step down resistors.
