Right, BUT you need to recognize an important difference, and sellers make this difficult by mixing their use of the labels Splitter and Hub. A SPLITTER is what you need for 3-pin fans. It has one input connector to the mobo header and two or more outputs to plug in your fans. It has NO other connections. It gets all power for its fans from the host header and thus is limited to the max Amps the header can supply - typically 1.0 A max total draw for all fans connected to that one header. A SPLITTER may look like a group or cable "arms", a small circuit board, or a box with connectors in holes on the side. Its connectors most often have 4 holes or pins, but sometimes three.
A HUB may look just like a SPLITTER, but it has one important...
