Fan Controller for the HAF X
Snyp3r
33
Sorry if this is a rather newbie question, but I want a definite answer. Is it possible to control the speeds of the HAF X case fans via some sort of fan controller? Every one i've seen has been 3 pin or 4 pin, not molex. Also if possible can you give me an example of one.
Are the molex connecters the large 4 pin connecter thingies, or am I mistaken?
This is a molex connector.
The fans at stock will probably have 3pin (its a confusing term to use but there is no nother) to Molex adapters on them. Fans natively connect via these 3 or 4 (if they have PWM control) pin connectors.
oh! I see what you mean!
So I shouldn't have any issues with compatibility.
Thanks for the clarification and help, and sorry for the noobiness 😛
