I have in my Corsair 400 case a H100i Radiator with 2 noctua 120m fans pulling air , 2 noctua 120m fans on the top, and one 120m noctua fan on the back. The radiator is placed in the front of the case and the 2 fans are pulling air thru the RAD into the case, the two top fans are pulling air downward int
o the case, and I have the back fan as an exhaust fan pulling air out of the case. My general question, is this fan set up optimal or should I change them around. Thank you all for the help
I realized that I also need to look into static pressure vs airflow. Currently all of my fans are Noctua NF-F12. So I would also appreciate the help in which noctua fan line I should use for the radiator and air flow. Static pressure vs air flow is confusing me and im unsure why a NF-F12 wouldnt suffice as an option of the radiator
