Question Fan plugged into AIO is not spinning ?
Complexic_1
32
DeepCool LS320 120mm AIO 220w TDP 4th Gen Dual Chamber Pump
Z690 Pro RS - motherboard
The DeepCool has a cord that connects the pump to the board and another cord that connects to the fan. The fan it is connected to isn't spinning. I checked the BIOS but (tbh it's a little confusing) I only see, what I can only assume is, the pump's internal fan or something. It says 3000+, which as I am to understand is normal, but IF that is referring to the pump itself then where do I look to find the fan's setting and not the pump's setting if the fan is plugged into the pump?
The computer itself is working 100% fine and the other fan I have plugged into the MB is spinning just fine.
You need to connect the fan as shown on pages 20 and 21 in your AIO manual, and not as shown on pages 22 and 23.
So, read your AIO manual again and go over the fan/pump cable connections.
