So, I have a bit of a problem. Also, should I forget later on, note that all temperature figures are given AT LOAD. All purchases to be made in Canada.
First, specs of relevance:
1080ti GPU; EVGA SC Black (H105 AIO cooled)
i7-6700k CPU (H60 AIO Cooled)
all five fan slots filled, using stock fan offerings. CPU and GPU have Arctic Silver 5 applied.
I'm running a NZXT Manta Case, which was unfortunately suffocating my graphics card due to getting the wrong blower style (mistake on my part). Fine, whatever, I got a liquid cooling kit and installed it on the card. 84c->53c, so I'll take it.
I now have a H105 Corsair AIO cooler radiator at the front of my case, and a pre-existing H60 AIO cooler on my i7-6700k. The H105 is cooling the GPU, and unfortunately I can't move it to a different position due to physical constraints.
Anyhow, my CPU is now baking, and the mobo system reports are also pretty high. CPU is reaching 89c at load, while sys is reporting upwards of 70c. Current config in use (I know this isn't the best, but it's not a ton worse than the others and I don't want to bother fixing it until I have a better idea of what I'm doing). Yellow is rad, red is fan:
CPU: 80
GPU: 54
SYS: 66
I've heard tell of static pressure fans and airflow fans, but I'm not really sure what I should be looking at. I'd like to try and keep the whole thing fairly quiet, but I also don't have a ton of money to be spending on fans to replace the stock offerings.
Here's my config I'm thinking would probably work well (please advise if you have ideas - just remember that the H105 unfortunately has to stay in the front in some capacity) yellow is rad, red is fan.... in this case though, assume the rads are on the outer side. I messed up the diagram there.
In testing with my current fans, it showed the best temps, still a bit high though:
CPU: 72
GPU: 59
SYS: 58
I was thinking of buying some of these:
https://amzn.to/2LQkR68
But I'm not really sure what I want here - I feel I need good intake airflow for the top vents and strong outflow for the exhausts in order to make this an effective solution, but I don't really know what I'd want for static vs. airflow type fans.
The case itself only has one open fan area, which is the rear exhaust. Top and front are meshed.
Thank you for any help.
CPU: 80
GPU: 54
SYS: 66
CPU: 72
GPU: 59
SYS: 58
