Fans for haf x
mannat
27
hi
i need some advice regarding replacement/adddon fans for HAF X case
im planing to put all blue fans. can some plz advice me which fans will fit in that case i need it also quite
i was looking at
http://www.coolermaster-usa.com/product.php?product_id=2946
for intake at front and 2 top exhaust fan
but not sure if these will align in my haf x case
if some one have same build can u advice me the quite and good fans for this case
thanks
smamic82
6
If you've decided that you want to replace the stock red 200mm fans with blue ones of the same size then your options are limited.
If you've got a soldering iron, and some skills, I think the best approach is to just replace the leds:
http://www.youtube.com/watch?v=KZ8OVK4AQs4 (by Cyrekk0)
Your advantage here is that you get to keep your LED button on/off function for the front fan. As far as I know, replacing the front fan with the coolermaster you listed above your Fan Led button would be non-functional due to the wiring. With that said, its no big deal and the easier way to go about it.
Also, you can choose the slightly less expensive http://www.newegg.com/Product/Product.aspx?Item=N82E16835233075 or http://www.newegg.com/Product/Product.aspx?Item=N82E16835233067
200mm fan led solder
basically you've got 2 choices
Yes they will work fine,you'll lose on/off like smamic82 mentions.
The mounting holes line up but the screws that come with the Megaflow 200 R4 don't work in a HAFX re-use the HafX fan screws.
http://www.newegg.com/Product/Product.aspx?Item=35-103-073&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=3
http://us.ncix.com/products/?sku=52545&vpn=R4%2DLUS%2D07AB%2DGP&manufacture=COOLERMASTER
mannat
27
i can change the LED's on front fan to blue so i don't loose on/off swith as mamic82
suggested.im gona put 3 more fans one at the front one on top and one more for exhaust, so total 6 fans
mannat
27
suggest me a nice one max 50-60$
