J jordan401reynolds Prominent Oct 31, 2017 39 0 530 Nov 30, 2017 #1 I have a 4gb gtx 960 and the fans have stopped working, and it's making a loud noise?
Solution Dark Lord of Tech Nov 30, 2017 Fan bearing or stuck fan , they won't kick on till the thermal load of about 64C is reached.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,669 1,808 159,590 Nov 30, 2017 #2 The fans don't kick in till about 64C , can you get them moving with the MSI Afterburner Software. Upvote 0 Downvote
J jordan401reynolds Prominent Oct 31, 2017 39 0 530 Nov 30, 2017 #3 Yes, they're working now that I'm using msi afterburner, it was also making a loud noise? which has now stopped once they are spinning but do you know what that couldve been? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,669 1,808 159,590 Nov 30, 2017 Solution #4 Fan bearing or stuck fan , they won't kick on till the thermal load of about 64C is reached. Upvote 0 Downvote Solution
J jordan401reynolds Prominent Oct 31, 2017 39 0 530 Nov 30, 2017 #5 Okay so it should be fine now? also should I close msi afterburner? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,669 1,808 159,590 Nov 30, 2017 #6 If it is fine now , shut down afterburner. I had that happen to my old MSI 960 , but everything was fine. Upvote 0 Downvote
J jordan401reynolds Prominent Oct 31, 2017 39 0 530 Nov 30, 2017 #7 tHANKYOU! i appreciate the help Upvote 0 Downvote
J jordan401reynolds Prominent Oct 31, 2017 39 0 530 Nov 30, 2017 #8 If it is fine now , shut down afterburner. I had that happen to my old MSI 960 , but everything was fine. The graphics card is now making lots of noise once I restart? how do I fix this? Upvote 0 Downvote
