It depends on what fans you got, and MB too. If the two fans will draw more than 1Amp from the fan_header on old version MB, the fans can kill the MB because they over draw power. Keep in mind, some of newer MB will have 2Amp fan_header.
So check the fan/MB specification first, if the fans don't draw more 1Amp or the MB has 2Amp fan_header, you can buy the fan Y-splitter
https://www.overclockers.co.uk/media/image/thumbnail/WC551EK_89194_800x800.jpg Otherwise use the PSU for your fans.
