[SOLVED] Fiber Internet Low Download Speed
Apr 12, 2020
I have 35 Mbps down & 3 Mbps up internet speed. When I test on Speedtest.net download speed is 33 Mbps, upload speed 3.5 Mbps but in Task Manager 35 Mbps download, 3.5 Mbps up. It is normal?
Sometimes I get 33.80 Mbps on Speedtest.net.
Have you ever gotten 35 Mbps? If not, and it really bothers you, then maybe contact your ISP about the issue, but honestly 2 Mbps translates to approximately 250 KBPS, and that much of a difference wouldn't be reason enough to complain to the ISP at least for me. But, like I said, if it bother you, you can show the speedtest result to your ISP and complain about the slower than promised speed.
If you're asking if it's normal for your upload speed to be that much lower than your download speed, yes. Upload speeds are basically always slower than download speeds for consumer accounts because the majority of home users aren't uploading vast amounts of data at once.
Upload speed higher than my speed plan and why the download speed is lowest? It must be 35/3 Mb.
Have you tried running the speedtest again? Do you get 33 Mbps consistently? Maybe you just ran the speedtest during peak time and got a slightly lower speed due to that. I wouldn't, personally, bother complaining about a 2 Mbps difference, but your opinion might vary of course.
Reactions: Saksocu Halime
