rockt111 :
this works.TRUST ME follow my instructions ..wizard creates a folder that is path generated( the from and the to path must be the same)
the answer is to trick the paths into believing they are the same.
1st use the wizard to create a new folder on your new comp.(tell the wizard it's from your old comp.) send it to the desktop.
2nd delete the files in the folder you just created.
3rd copy the files from the old wizard( files only) and paste them in the new file you created.(make sure they are in numerical order)
4th now tell the wizard that you are transfering to the new comp.(on the desktop) done!!. restart your comp each step to insure
the info is in the registry. this proceedure works( sometimes you might have to repeat thes steps, because for some reason
the path trigger switch doe's not reset.
I have no idea how you figured this out, but it worked. Thank you.
