Hi there!
So I overclocked my 10900k to 5ghz, and when I play games or work on music in a DAW(processor demanding stuff) it nicely bounces around 4.8 and 5ghz (it runs at that frequency even when it's idle cause I set it to constantly be at that speed), with temps being under 70 degrees ( 50-60-65ish most of the time(fans are barely spinning too)). But when I run a stress test with aida64 and it goes to 100% load but the frequency drops down to 4.69ghz. Aida64 says its not throttling thought. Any idea what is happening here? Is it normal?
And yeah, the temps while stress-testing jump around 84-86, which from what I've seen on the internet is normal. But would also like to hear your thoughts on that as well.
Im using a Noctua NH-D15 with it.
One more thing about the temps. I used to have a problem where it would run in mid 70 to mid 80 in games before and would go above 100 under stress test, but then I reapplied the thermal paste and it become acceptable, 84-86 as I said earlier.
So yeah. Looking forward to hear what you guys think
SPECS:
MSI MAG Z490 TOMAHAWK
i9-10900k (with Noctua NH-D15)
3080ti
Kingston hyper x fury 32gb
Corsair 850w
SPECS:
3080ti
Corsair 850w
