Fire or lightning trapsin?
Archived from groups: alt.games.diablo2 (More info?)
Patrick Vervoorn wrote::
(I remember there had been 4 unanswered messages from you. My newserver
seems to have decided to purge them over the weekend. This morning I
only found this one left. So the reason why I don't answer to the otehr
messages is just, that I don't see them anymore)
> In article <d54sp4$d33$1@domitilla.aioe.org>,
>>Which means that I'm currently very short on runes, the rune mule was
>>made just for keeping them and not yet filled.
> Aiii... That's unfortunate. And it's an event like this (I think I lost a
> pair or +2 Marrowalks and possibly a bonehew) that made me decide to get
> another set of LOD/D2.
I'm considering that, too. Unfortunately my other computer doesn't work
very reliable, but it should still help. IIRC the battle chest sells for
15 euros, so that's no problem.
> Does this also mean you lost all your Ral runes? 🙁
Most of them. I brought in all my characters, piled up the runes, and
then tried to bring in the mule, to pick them all up. First it said
"Cannot join game" -> *shock* -> then when I switched to another char
again -> "game doesn't exists" -> *panic* -> but finally I had to accept
the loss ... 🙁
>>>Which is why i was questioning the fire/lightning sorc. :)
>>We can try to use the experience to build even stronger characters, or
>>we can try to build something new.
> Like I said, I'm not sure a Fire/Lightning sorc is that new. It probably
> has been tried when 1.10 got out, and maybe deemed a bit weak... Which is
> why you see few guides describing one.
Let me rephrase that: "We can try to use the experience to build even
stronger characters, or we can try to build something unusual".
Seriously, how weak do you think CL will be if only 40-45 points can be
spent on the lightning tree?
I decided not to try a FO/FB sorceress (it seems to be too much
mainstream) but if CL is too weak, I'll just retire her or play her in
nightmare, but not go to hell.
Given a limit of ~40 points, Nova seems to be an alternative to CL:
Nova with 41 points in:
SF: 1
Nova: 20
LM: 20
-> Mana cost: 34
-> damage: 495 - 710 (ø602.5)
Static field we want to have anyways, so the one point is just perfect
there.
CL with 42 points in:
CB: 1
LN: 1
CL: 20
LM: 20
-> Mana cost: 28
-> Range: 13.3 Yards
-> Damage: 3 - 1147 (ø575)
-> Hits: 9
Nova can hit everything in screen so against big crowds, Nova could deal
a higher amount of damage, but that's will be a very rare case I guess.
With 41 points, Nova is a tad stronger than CL. But this turns if more
points can be spent, e.g. on the synergies:
CL with 46 points in:
CB: 5
LN: 1
CL: 20
LM: 20
-> Mana cost: 28
-> Range: 13.3 Meter
-> Damage: 3 - 1317 (ø660)
-> Hits: 9
Now CL deals more damage in average.
Nova doesn't need to be aimed. Is that a benefit? Nova probably has a
shorter range. How much of a problem is that?
600 average damage per nova means to cast 10 novas to kill one (or a
group) of the act 5 standard Baals minions. That's not really
convincing. Nova needs even more mana than CL.
It seems Nova is an alternative _only_ if skills point are scarse, and
no more than 41 are available for lightning (I don't count teleport
here, which you'll want or not in both cases, CL and Nova).
>>I'm gambling coronets. I gambled a few with + 1 skills, but none for
>>sorcress skills. So I keep hunting for money, running some minor bosses
>>for items and then gambling the money away on coronets.
> Keep it up, I think you already can get every possible modifier on those
> gambled coronets there are.
I just checked the arreats summit and it seems coronets don't have
enough magic level, but tiaras and diadems have.
> And if you ever gamble a blue diadem or tiara
> with 3 sockets and a second mod: don't sell it for gold, but keep it!!
> Some of those are _very_ valuable, though I didn't know that at first
> either.
What is the reason for the value? IIRC runewords can't be made in
magical items, but 3 sockets are still very nice.
>>>That's how the Fireball guides state it: simply start pumping fire bolt
>>>from the beginning, switch to Fire ball once that becomes available, and
>>>keep pumping them until your other options are available (with an FB/FO
>>>sorc, that's at lvl 30 when FO becomes available). Normal is supposedly a
>>>breeze doing this.
>>It is. FB is incredibly strong in the early ares. I'm lvl 22 and can
>>almost fight my way through the chaos sanctuary solo.
> Sounds good. And the way it should be; a sorc should have no problems
> there...
It depends. If you put your bets on a lvl 24 or higher spell, the start
would be more difficult. I got fire ball at lvl 12, so I already have 10
points in fire ball and 7 in its synergy fire bolt (I saved some, and
also learned teleport at level 18)
>>The only problem is mana. I tried to live on base energy as adived by
>>some sorceress guides. I gave her a lot of +mana items (+20 on amulet,
>>+17 on rings, +31 on armor, +17 on helm, +7 on shield, +24 on orb and a
>>few +mana charms). Yet, fire balls fire so rapidly that after a short
>>while she's out of mana and need to drink a blue potion. Fights are
>>burst fights, she can take down hordes of monsters quickly but needs
>>time to recover between fights.
>>Currently I think base energy is too restrictive, and I'll put a few
>>points in it, maybe boosting it to 50 and see how that works.
> Well, my advice would be to NOT do this, but it's your character, and if
> you're not going to trade/acquire any of the +mana items, you might have a
> hard time, and some energy could be handy then.
I'll see. I definitely don't have the equipment to outfit three
sourceress properly. This one will be the poorest girl of the family for
a while. My other sorc has 100+ points in energy, so 50 is already a big
cut-down for me.
> Keep in mind these are then points you will never be able to invest in for
> instance Str, to equip a Spirit Monarch (which adds ~100 mana of it's
> own), and adds numerous other benefits, which might outweigh the 50 points
> in energy..:
I still have the 100 points saved, and could do it. So it's not yet, too
late, it's just a question of balance.
> 50 Ene: 50 x 3 = 150 mana added
> Spirit Shield: ~100 mana, FCR, 35 psn/cold/lit res, +2 skills, etc.
> (Of course, a monarch needs a lot more investment of str... :)
+2 skills is nice, and the other mods are good too. Also the shield has
a good defense, but I don't know how important that is?
> I was at that moment guzzling blue pots like crazy. But the earlier levels
> are the most difficult for a sorc, especially if you're not going to spend
> points in energy, and use equipment to get mana...
> In the end, it's more than worth it, I think...
I know. I'm just worried about the path there :)
>>I need to sum them up first, but I think my fire wall/frozen orb sorc
>>has already more than 30 points in cold skill. FO needs a lot of
>>prerequisites (6 I believe) so that 30 points only mean 24 for FO/CM
>>itself. Even if FO is strong, this will limit it's use quite a bit.
> But it's powerful and cheap compared to the alternatives...
Yes, that's right. If we use the 41 points that I used for my
calculation above, FO/CM will be stronger than the nova build, and FO
travels over the screen shooting shards in all directions while Nova is
fixed to caster and doesn't go through doors as easily ...
So if power is the only goal, FO/CM is a must have.
>>Fire wall is easy on the skill points. It just needs two prerequisites,
>>and has no synergies, so you can max it out with ~42 total points in the
>>fire spell tree.
> I've also heard very good things about Meteor and Blizzard, so those might
> be options too... (Just to add more confusion... :)
If I made no mistake in my calculations, Meteor is the most powerful
fire spell. I still hate the delay between cast and impact.
Blizzard ist the most powerful cold spell. But it doesn't hit 100% reliably.
It's a matter of taste at this point, and a matter of your playing
style. A bit similar to my fire walls, which I like very much but others
consider unuseable.
>>Right. The only question is, if we want to accept the challenge, or
>>chicken and go to the easy way of FO/CM + additional spells :)
> I think I'm going to try the FO/FB route, but don't let that discourage
> you... :)
Hmmm ... you know that I have a high opinion of your experience and
playing skills. If you say FB/CL is too weak, I'll believe that.
Maybe the nova build can keep up a while, but finally FO/CM will
outperform it.
[Tri-Elemental]
> Well, Cold via FO, Fire via FB, and Lightning via SF as a boost/backup is
> about as Tri-Elemental you can get. But SF is of course never a killer, it
> can only help to weaken the targets...
I wouldn't count that as tri-elemental, becuase you have 30, 40 or more
points in each of fire and cold, and 3 or so in lightning.
> But a 'real' Tri-Elemental sorceress has been impossible to do since 1.10.
> Since I never played a sorc in 1.09, I don't know how powerful they were
> in that version...
I played 1.09 but I didn't play my sorc so far that I would have real
experience with that. I used a combination of fire ball and charged bolt.
> Apparently Nova is the basis of a build which some people over in
> alt.games.diablo call a 'RocketSorc'. However, when I asked how this build
> looks specifically, I didn't get an answer...
> It is supposedly very powerful, but I have no idea if this build can solo
> hell...
While you can improve most fire spells with their synergies for a long
time, Nova maxes out at 600 avg damage after 41 skills points spent,
without otpion to add anything more.
If you some day notice the 600 damage are too little, you wasted 41
points and can't do anything to improve the situation.
[Patricks suggestion: Kitchen general sorc - freezes and fries friend
and foe]
>>>20/15 FO/CM (35)
>>>20/20/20 FB/FB/FM (60)
>>>1/1/1 SF/Tel/Warmth (3)
> I think the above is more or less what my FB/FO sorc will look like. Now I
> only need time to start playing some D2. :)
>>Ok, so we should abandon the idea of a fire/lightning sorc ?
> I'm not saying you should, I'm just saying I have my doubts this build
> will be workable in Hell. It will probably do very good up until NM, but I
> think it will slow down considerably when you reach Hell..
Hearing this from you, I understand the message as "don't try it, I know
it won't work", so I'll not try it, except maybe for fun.
> Regards,
> Patrick.
c.u. Hajo
>>I got a Duriels shell from a thankful player whom I had rushed a bit. (I
>>didn't ask for it, it was just luck.) Now my sorceress' merc is wearing
>>duriels shell and the shaftstop was given to my assassins merc.
>>My sorceress merc still can't use the bonehew, although he catched up as
>>much as possible, he's now lvl 78 while my sorc is lvl 79. I think a
>>socketed helm with one or two flawless or perfect amethysts could solve
>>the problem, but I didn't try that yet.
> Congrats! At least with the added +Str from Duriels, the bonehew has
> gotten closer. 😉
Both got a level yesterday, the sorc is now 80, the merc 79.
The merc got a helm socketed with a flawless amethyst. This gave him 196
str, so he can use the bonehew now!
The current helm will only be a temporary solution. I'm looking for a
rare helm with nice mods and a socket to put in a flawless or perfect
amethyst if it doesn't have +str on it's own, or maybe a nice unique
helm. I'll see if something useful drops.
I'm visiting some of the bosses and some unique monsters regularly now,
to kindly ask them for better items ;o)
I just wanted to let you know, that one more of your gifts is now in
use, only the Hone Sundan is still waiting to be socketed and then used
by my assassins merc.
> Regards,
> Patrick.
c.u. Hajo
In article <427650a9$0$281$edfadb0f@dread11.news.tele.dk>,
>> That part of it looked indeed very nice. But VoR has no built-in IAS; is
>> Zeal + Fana enough to hit the breakpoint? That would also imply I'll
>> easily hit the 5fpa breakpoint with the Stormlash, since it has some
>> built-in IAS...?
>With level 24 fana a scourge will get 5 fpa with zeal and no other ias,
>with you want to get 4 fpa you will need 39% more ias where stormlash
>gives you he 30% so you will need 9% more from somewhere.
>To cheat a little you can use andy visage which gives you 20% or
>highlords that also gives you 20%.
That's nice to know; Andy's Visage might be the option, although I rather
dislike it's negative fire (was it?) resists. I need some specific stuff
to counter that...
>> Since I play SC, no risk of losing it of course. 😉
>those were the days 😉
*hehe* :)
>> But then again, it packs a lot of nice mods, and it's probably the best
>> helmet I have. Hmm, well, now that I think about it, I do have an
>> Andariel's Visage on a mule somewhere. Is this a nice Zealot helmet?
>Cheated and commented that earlier :)
I'll dust it off and see what it does for the Zealot. I seem to remember
it has some crazy level requirement, though, so I won't be able to use it
anytime soon...
>> That's the problem with GA: it ups your max resists, but adds no resists
>> of itself. That's one thing Fortitude has: some built-in res too.
>All my GA's has build in res, they comes with UM build in:)
>that equals yout the extra res.
Yeah, that'd certainly be an option. I might have put an Um in the perfect
(200% ED) GA I even found myself at the start of the ladder; it's
currently on my Hammerdin.
>> Not only that, I have plenty of weapons on mules he'd like to have. This
>> is less so for an Act 1 rogue. :)
>I think the choices are too many after the new runeword got released.
>I found a tomb reaver the other day, back in the pre new runeword days i
>would consider it as a very good stick for a act 2 dude, now i stashed
>it away on a mule and maybe it will stay there, depending on my luck
>finding eth polearms.
Tom Reaver; that's the one with the variable sockets and the auto-revive
function on it? I've never found one, but I saw ethereal ones with 3
sockets trade for insane amounts of Ists in the trade forum.
One of the sticks I still like very much for builds which have only a few
minions (i.e. sorc, about any melee build) is that unique polearm
(Thresher I think) that has a CtC Decrepify on it. That really slows down
crowds, and makes thing more manageable.
Is there any alternative for that polearm, that I haven't thought of?
I'm also making an Obedience polearm: I have an ethereal 5 socketed
Thresher, and all the runes for it, _except_ Eth. Argl! That'll teach me
for cubing up all those low runes! :)
>After playing, if not on a daily then weekly basis, since d2 got
>released back in summer of 2000 i tried it many times. But i have to
>admit its within the last year or so i got it like this, before i also
>could enjoy playing through normal with clearance of all areas and all
>quests and so on.
Can't beat that; I'm a lot 'fresher' than that. :)
>UNIX (n.) : See archaic.
Patrick.
In article <d57asr$3ju$1@domitilla.aioe.org>,
>> gotten closer. 😉
Nice! That's indeed one of the ways to equip the Bonehew earlier. Did you
already socket it with 2 x Amn, or is that still on the todo list?
If you need Amns, just try getting some for a pgem each. I'd offer 2 pgems
max a piece, or 3 pgems for 2 Amns. They're not that valuable.
And how is the merc performing with it?
Browse around on the Arreat Summit, and check if you see anything you
like. 😉
Nonono, the Bonehew was not a gif from mine: it's an item we found
together, and since I have plenty of Bonehews it was your to keep. This
was no gift!
Regards,
Patrick.
Patrick Vervoorn <patrick.vervoorn@NOSPAM.perihelion.demon.nl> wrote:
> In article <d55e8b$k8f$1@domitilla.aioe.org>,
> I don't really know... It's just a gut-feeling, combined with my
> experience with the FO/CL sorc I have: it's only when I had the points
> left to start pumping CL + LM + LI that he started to kill with CL. Before
> that, CL just felt rather weak. And especially if you haven't pumped the
> synergies of CL, it costs a lot of mana for relatively little damage. Only
> when the synergies are upped, do you get more damage for no extra mana
> cost...
You're right, it will never be as powerful as fully synergized CL, but
still far from useless. Also, I ended up using lightning instead of CL,
cause it deals more damage, consumes less mana, and pierces through
monsters (so, if you can get them lined-up, they won't last very long).
For example, this is how I built one of my tri-elementalists (SP, SC,
matriarch, lvl 89):
_Cold skills_:
Frozen Orb - max
CM -1
+preqs
_Fire skills_:
Warmth -1
FM -1
Firewall - max
+preqs
_Lightning skills_:
Static Field -1
Teleport -1
Lightning -max
Chain Lightning -max
LM -currently 6 (all additional points will go here)
+preqs
And, as you probably guessed, decent equipment makes all the difference in
this kind of build, because it compensates for the lack of skill points.
This particular one uses:
HotO, Harley (with cold facet), Mara's amu, upgraded Viper (with cold
facet), Arachnid's belt, Magefists and 3 cold + 1 lightning skillers.
Oh, and a Stormshield... :)
Anyways, if you're interested in taking her for a test-drive, drop me a
mail and I'll send you her save files.
Duergar
On Tue, 03 May 2005 10:17:03 +0200, Patrick Vervoorn wrote:
> [snip]
>>gives you he 30% so you will need 9% more from somewhere. To cheat a
>>little you can use andy visage which gives you 20% or highlords that also
>>gives you 20%.
> to counter that...
I have one of those waiting for my smiter, i will socket it and put in a
RAL to even out the negative fire res on it.
> [snip]
> anytime soon...
Yeah, level 82 is a bit on the high side.
>>> resists of itself. That's one thing Fortitude has: some built-in res
>>> too.
>>All my GA's has build in res, they comes with UM build in:) that equals
>>yout the extra res.
OK, i thought hammerdins where using viper until they got the runes for
enigma.
>>> This is less so for an Act 1 rogue. :)
>>I think the choices are too many after the new runeword got released. I
>>would consider it as a very good stick for a act 2 dude, now i stashed it
>>away on a mule and maybe it will stay there, depending on my luck finding
>>eth polearms.
Yep thats the one, mine is not eth and middle stats except for mf which is
78% of 80% max and with 3 sockets.
My bears merc is using that one since i only do physical damage and need
some way to break immunes.
My level 91 summoning necro's merc is using obedience in a non eth cryptic
axe, haven't had much luck in cubing runes into eth cryptic axes.
My hybrid ama's merc uses a eth cryptic axe with insight so she can fire
freezing arrows and throw lightning fury without having to worry about
mana. Only setback was it "costed" me 4 eth cryptic axes before i got one
with 4 sockets, the rest was 1, 2 or 3 sockets, not even a 5 socket for a
little obedience.
And just a couple of days ago i made a new insight for my boners merc in a
eth collusus voulge, only drawback is the insane str req on it, 200 in the
eth version, but with a griswold armor with 3 pamethyst he should me able
to use it from level 65 or 66.
I'll try look later, maybe i have an ETH rune on my scl char and then you
can have it.
>>After playing, if not on a daily then weekly basis, since d2 got released
>>back in summer of 2000 i tried it many times. But i have to admit its
>>within the last year or so i got it like this, before i also could enjoy
>>playing through normal with clearance of all areas and all quests and so
>>on.
With time you will be there too :)
Don't ask about my sig, it's just random quotes from a file :)
Sonni
In article <hzkb4tjnsutw$.157duapmgwuw6$.dlg@40tude.net>,
I have CL maxed, and LI is being maxed, but I'm a bit lazy, so I just spam
CL constantly. If you hit the first monster, the rest gets hit
'automagically'. :)
>matriarch, lvl 89):
>_Cold skills_:
>Frozen Orb - max
>CM -1
>+preqs
>_Fire skills_:
>Warmth -1
>FM -1
>Firewall - max
>+preqs
>_Lightning skills_:
>Static Field -1
>Teleport -1
>Lightning -max
>+preqs
Do you see any alternative way this could be done? Because I think you
picked the Cold (FO) and Fire (FW) skills which need least points to
become effective. It's only in the lightning tree that you need to put
more points to get more damage...
Equipment makes all the difference...
Nice stuff. Which, again, reminds me I still have a Vex on my rune mule,
and even have a 4 socket flail somewhere, just for making HotO.
Some nice gear there; cold facets, Mara's, Arachnid, and the skillers.
What's the stormshield for? Maxed Block sorc? Or just for it's other mods
(isn't this the shield which has lightning absorb?) Since I can't easily
access the Arreat Summit, I cannot look up it's mods easily, so I'll have
to check this evening. 🙁
What are her resists in Hell, with the above stuff equipped?
I'd be interested, I'll fire off an email right away, and see my headers
for what my email is.
Regards,
Patrick.
In article <pan.2005.05.03.11.43.02.40414@sonni.org>,
>> to counter that...
I see a lot of people doing that; not sure I'm going to do that. Some fire
res charms in the backpack should also do it, leaving the socket open for
something else...
>> anytime soon...
So I can equip it at the same I can equip the Stormlash. :)
>enigma.
FCR eh? Well, I had no spare Vipermagi left, and definately at that time
not the runes for Enigma. I now have a spare Viper left, so I might swap
it out, to free up that GA. (No idea where to put it though :).
I _finally_ made my first Enigma: traded my ass off last saturday, and
made it in a nice 502 def Archon Plate. Got the lowest possible +def
(+750), but still, it's an Enigma! It's currently on my skelliemancer, and
he seems to like it a lot. It's amazing how much firepower he carries,
especially if I regroup The Horde using a teleport, and all of them dive
on top of the nearest monsters. :)
It certainly isn't going on that boring Hammerdin: a waste of a perfectly
good Enigma.
Ah, OK. Still looks nice on paper. :) No idea how it performs in
practice...
>little obedience.
Doesn't a Cryptic Axe given to Larzuk always get 5 sockets? The cube
recipe is indeed quite risky. I messed up a very nice ethereal Giant
Thresher using that: got 3 sockets, instead of the 4 or 5 I hoped for. 🙁
Quite some specific gear; especially grisworld's armor isn't exactly
packing with merc-type mods. :-\
>can have it.
I already have 2 of the runes before Eth, so I can probably cube one
pretty soon. :) But thanks for the offer. :)
*ehem* If I get time to play it; lately I've had very little D2 time, so
I've only been able to do some small test-drives, some trading, and maybe
a few quick MF-runs.
I won't then! :)
Regards,
Patrick.
>>matriarch, lvl 89):
>>_Cold skills_:
>>Frozen Orb - max
>>CM -1
>>+preqs
>>_Fire skills_:
>>Warmth -1
>>FM -1
>>Firewall - max
>>+preqs
>>_Lightning skills_:
>>Static Field -1
>>Teleport -1
>>Lightning -max
>>+preqs
> become effective.
True, and even with this distribution of skills, where I used "standalone"
skills in C&F trees, you won't have enough points to max lightning spells.
That is THE biggest problem with tri-elementalists in 1.10 - there simply
aren't enough skill points, and that's why they always turn out to be
average builds. Interesting builds, but average power-wise.
Simillar build would be: cold and lightning trees stay the same, and swap
FW for hydra...
Basiclly, anything is doable, but some combinations would be too slow and
tedious.
A +3 skills Eschuta's would be even better offensivly, but lacks huge
resists from HotO.
Block (not maxed, did a split between vit and dex) and a very nice 35%
damage reduction + resists + very high defense.
With help from some small charms 68/75/69/55. Mara's is +21, and SS is
socketed with PD.
> Regards,
> Patrick.
Mail is on the way...
Duergar
On Tue, 03 May 2005 14:12:11 +0200, Patrick Vervoorn wrote:
> In article <pan.2005.05.03.11.43.02.40414@sonni.org>, Sonni Skammelsen
>>> rather dislike it's negative fire (was it?) resists. I need some
>>> specific stuff to counter that...
> something else...
I currently have a lot of socket quests since i mostly bring a mule with
me to guardian which gives me 6 socket quests for each char :)
>>> remember it has some crazy level requirement, though, so I won't be
>>> able to use it anytime soon...
Not to late then :)
>>> perfect (200% ED) GA I even found myself at the start of the ladder;
>>> it's currently on my Hammerdin.
>>enigma.
hehe :)
> good Enigma.
One peice if gear i only can dream of, and if i got it i really didn't
know where to put it, but necro sounds ok, even if he will lower his mf% a
bit.
>>> auto-revive function on it? I've never found one, but I saw ethereal
>>> ones with 3 sockets trade for insane amounts of Ists in the trade
>>> forum.
>>is 78% of 80% max and with 3 sockets.
> practice...
Think it does ok, but efter the new runewords i think they are better, at
least my necros merc is doing more than ok with his obedience.
>>> me for cubing up all those low runes! :)
>>cryptic axe, haven't had much luck in cubing runes into eth cryptic axes.
>>little obedience.
Yep it always gets 5 sockets, which is one to many when you really need
insight, that why i had to use the cube and hope :)
The next i get will go to larzuk for 5 sockets and a good roll on the
obedience.
I still have a eth collusus voulge if i need a new insight, which i think
i will go for when i redo my avenger.
>>a eth collusus voulge, only drawback is the insane str req on it, 200 in
>>the eth version, but with a griswold armor with 3 pamethyst he should me
>>able to use it from level 65 or 66.
Not really, but when i can do it i will change the griswold armor with
leviathan when the merc reaches 174 in natural str and then i have the
griswold ready for the next merc that needs a str boost for either the new
eth collusus voulge, bone hew or somthing alse that needs high str.
>>can have it.
If you can't wait try to look me up on *tsfts2 or *tsfts3 then i'm pretty
sure i can help you with a low rune or two.
Sonni
In article <pan.2005.05.03.13.00.55.650889@sonni.org>,
>> something else...
It's not that I don't have enough socket quests (plenty left! :), but the
fact that that helmet-socket can probably be filled with something nicer
than a Ral...?
>Not to late then :)
Will he be happy when he reaches lvl 82! :)
>hehe :)
Time for yet another Paladin build, one that can use the GA to it's
fullest extent! *ehem* 😉
>> good Enigma.
>bit.
Yup, he had more MF with his PTopazed Skullder's Ire, but the added
goodies from Enigma make more than up for that.
Cost me 12 Ists (6 each for Jah and Ber), an Ith from my rune mule, and a
Mal for the 3 socketed Archon Plate. Oh well, one other dream fulfilled!
Obedience indeed seems to deal an insane amount of raw damage. Still
curious how my first Obedience turns out. Hopefully this evening... 😉
4 socket polearms trade for Ist+ on the forums. A bit expensive if you
just want to make Insight in it. :)
>obedience.
Yeah, I also have an etheeal Cryptic Axe without any sockets on my
'socketable' mule. I could give it to Larzuk for a straight 5 sockets, or
I could gamble using the cube recipe and hope for 4. Thing cost me an Um,
un socketed. With 1-3 sockets, it becomes useless, with 4 sockets it's
value rises to ~Ist, and with 5 sockets it stays Um. Hmmmm... I'm not much
of a gambler. :)
Too bad about the Str req's on Collossus Voulge's indeed.
That's also a solution, yes. And while Leviathan isn't exactly a bad
armor, it also isn't packed with merc modifiers. I think I'd still prefer
a Duress over a Leviathan...?
If things don't work out, I'll msg you. Again thanks for the offer!
Patrick.
In article <1yie2fbw1vh9$.owf7kesmtfwf.dlg@40tude.net>,
>> become effective.
Duly noted. :)
>FW for hydra...
Does Hydra work in Hell?
>tedious.
And expecially in the latter parts of Hell, Act 5, when you get monsters
with loads of life, very, very tedious. :)
>resists from HotO.
I found an Eschuta's myself, but it only has +2 skills. 🙁 Anyhow, my
second sorc is going to be more of an experimental one, and will be
wearing a unique setup. Tal's Set offers so many goodies, that's it's very
difficult to replaces parts of it with unique: you lose a lot that way.
Ah, yes. Never found one though, but the 35% DR is very nice. I'll try to
remeber to look up it's stats on the Arreat Summit this evening, plus I
will of course see it 'live' when I load in your character in SP.
>socketed with PD.
Nice. All of this self-found in SP!? That must've taken some time?
.... and received ok. Full report will follow here! :)
Regards,
Patrick.
On Tue, 03 May 2005 15:45:50 +0200, Patrick Vervoorn wrote:
> In article <pan.2005.05.03.13.00.55.650889@sonni.org>, Sonni Skammelsen
>>> fire res charms in the backpack should also do it, leaving the socket
>>> open for something else...
> than a Ral...?
Like a rare jewel or magic jewel with the ruby prefix and a nice suffix
and if it's rare some other nice prefixes too :)
then you would even out the negative fire res.
I would guess some like +30% fire res, +9 max dam, 30% extra dam, 10 res
all, 15% ias and +10 min dam.
I think you could use that one :)
> [snip]
>>a bit.
12 ists, not even if i hadn't used any of my ist's for trading i would be
close to that, a think i had 6 ists all season where i so far have used 3
of them in trades.
Doesn't seem that even if i kill a lot of monsters on my way i can get
runes to drop for me.
Not only raw damage, but you get 40% cb, enough res all to max your merc
res, enchants himself very often so he get a little fire damage, but most
important a lot extra AR so he just keeps on pricking with his stick :)
I know, once i was stupid enough to ask the price for one, and it was ist,
then i decided even if i had the throw 100 eth cryptic axes, 100
pamethyst, 100 rals and 100 amns away before i got one with 4 sockets it
would still be cheaper. No way i will pay that much for a merc stick, then
i can go on without it beeing eth.
>>obedience.
> of a gambler. :)
An Um for a item you don't know if you can/will use, isn't that overpaying
just a little.
Iirc i have found 7 or 8 eth cryptic axes since the new runewords was
released, so i don't think they are that rare so it should cost you an UM,
but that just my opinion.
>>new eth collusus voulge, bone hew or somthing alse that needs high str.
I have a small problem with keeping um's in stock for all those duress
armors, maybe i can start selling cryptic aex to you to get my stock up
again :)
OK
Sonni
In article <pan.2005.05.03.15.02.39.264467@sonni.org>,
*haha* That sounds like one godly rare jewel. Is the above even possible?
>of them in trades.
I didn't get them by killing monsters, but by trading away stuff. Most if
the Ists came from gambled circlets/coronets: 5 Ist for a +2 druid
elem/20fcr/res-all/str/life one, 2 Ist for a +2 pala/30frw/res-all/life/..
and 7 Ists for a +2 necro/20fcr/res-all/life/etc one.
And some misc. Ists for less valuable gear. Took me all of the Ladder 2 to
get it though...
Yes, Obedience packs a lot of interesting mods. But I've written loads of
text about that before, it does lack life leech, so I'm still not
convinced an Obedience polearm is better than what I'm using now (ethereal
upped Hone Sundan).
Anyhow, once I have the Obedience, I'll try it...
But if you really want one...
>> of a gambler. :)
>just a little.
Yes, but I was getting tired of trying to find one myself. And I had two
trades running in parallel, one for the ethereal Thresher and another for
the ethereal Cryptic Axe, so that's why I decided to take 'em both.
I tried for a Pul, but that didn't succeed, unfortunately...
Well, I've also found plenty of Ums, and the Hellforges in NM and Hell
regularly give one, so these are not too plentiful either. I think most
prices in the trade forums are quite realistic, and based upon an items
'rareness' combined with it's usefullness.
>again :)
Why not. I cubed up a few Puls a few weeks ago, to get more Um's. :)
Regards,
Patrick.
"Patrick Vervoorn" <patrick.vervoorn@NOSPAM.perihelion.demon.nl> wrote in
message news:295f1$42723c1c$82a1d3bf$9321@news1.tudelft.nl...
> In article <pan.2005.04.29.13.21.17.363683@sonni.org>,
> >> wws = Witchwild String, I presume? I have a few of those... :) Upped?
> >> Socketed with what?
> >Yep.
> >It's not upped, but socketed with 2 amn's for ll.
The wws fires magic arrows? How much physical damage does it actually put
out to leech from?
I have one as a missle weapon for my tesladin, but still haven't put
anything into the sockets since I couldn't decide what would actually be
usefull. I was leaning to one or two shael runes to get his shooting speed
up.
>matriarch, lvl 89):
>_Cold skills_:
>Frozen Orb - max
>CM -1
>+preqs
>_Fire skills_:
>Warmth -1
>FM -1
>Firewall - max
>+preqs
>_Lightning skills_:
>Static Field -1
>Teleport -1
>Lightning -max
>+preqs
OK, I received and played the character I received from you... Nice build,
and all three chosen spells seem to do a decent amount of damage. So
perhaps this is doable.
The only problem I had with her is that she has a damned low amount of
mana: 448. Just a few FO's, lightnings or CL's, and she's out of mana. I
see you've anticipated this by filling rows 3 and 4 with mana potions, but
still, I don't like running out of mana, so I will still be planning for
more with my sorcs (without adding to ene, but by adding +mana charms for
instance).
Also, the Stormshield (a Monarch, requiring 156 str, but having +30 str of
it's own) seems to have been equipped with a trick, since her base str
with the Stormshield removed is 136. Anyway, it doesn't seem to be a
hardcore character, so I now cannot put back the Stormshield. 😉 You
equipped this with a load of +Str charms equipped, and then unloaded the
charms again, expecting never to be killed?
Anyway, nice to see she's quite capable of killing stuff with all three
spells...
Regards,
Patrick.
It should be, i checked AS and rare items can have 2 - 6 pre and/or
siffixes.
I think you have to be extremely lucky, but it can be done :)
>>of them in trades.
> get it though...
Hmm, there must be lost of difference between sc and hc then.
I tried selling diadems with +2 class skills, 20 fcr, 30 frw, +life,
+mana, +str, ll, ml and up to 19 res all, and people have been laughing
of it and the only replay i got on the price was around PUL.
I currently have a couple os +2 pala skills and a +2 mam skill diadem on
mules, maybe even more than that, maybe i should try ingame trade in
stead of forum trades.
> upped Hone Sundan).
Try and i think you will love it :)
I really did/do, but not at that price :)
>>>of a gambler. :)
>>just a little.
But you tried :)
Soon i want to get runes too :)
>>again :)
Cubed up a few puls blah blah blah :)
I've gotten a total of 2 PUL's from hf and found one from one of shenks
buddies, and then i stole onefrom Hansi.
I used one PUL for my HotO, which of course is gone by now:)
And use an other to upgrade my 292% ripcracker for my bear.
The 2 i have now could be use for a UM unless i either get an UM or a
GUL from one of my 6 soon to do hf. If i get a GUL then i simply need
one of those PUL's to make myself a new HotO, that is by far the best
caster weapon i ever tried in the game.
And since i just upped some unique armors, made VoR and some other funky
stuff i don't even have LEM's left for cubing PUL's.
So basicly i just hate Hannes for finding all those runes that belongs
to me 😉
Sonni
A fool and his UNIX are soon ported.
In SC such a diadem as you describe would be worth a fortune and
the bidders would be people with PvP caster chars. But I believe
it has obvious value even for PvM and anyone who thinks it to be
only worth a Pul is a actually a noob :) (really).
In article <4277bc12$0$275$edfadb0f@dread11.news.tele.dk>,
>siffixes.
It looks indeed possible, but a jewel like that would be very valuable. :)
>> get it though...
As the other posted said, a diadem with the mods described above would be
worth several HR's. No idea why/if it's not worth that much in HC...
We'll see, we'll see. :)
>But you tried :)
Of course I did, because I felt an Um was way too much also. But since the
market seemed to agree that Um was about right, I finally followed it,
because they weren't exactly dropping like flies...
Sorry, I couldn't resists typing that! :)
>to me 😉
Well, it's not as if HR's are dropping for me like flies: one Vex at the
start of the ladder (with Vex not technically even being an HR), and one
Lo from one of Pindleskin's buddies...
Regards,
Patrick.
Well this is EuHCL
I will try list a few of what i tried to get rid of for a few runes.
rare circlet
+2 paladin skills
7% ml
+7 str
11 res all
- no bids
rare diadem
+2 pala skills
7% ml
5% ll
19% cold + fire + poison res
38% lightning res
- no bids
rare diadem
+2 amazon skills
7% ll
+12 str
12% poison res
damage reduced by 3
2 sockets
- valued a PUL
rare diadem
+2 pala skills
+7 dex
+81 mana
17 res all
- no bids
And all are rerolled from other +2 class skills where they also inlcude
frw and fcr and it was the same, all no bids, the closest i got to
something was the one they valued a PUL.
Sonni
I'm a Schizophrenic, And neither am I.
> Well this is EuHCL
Note that the diadem described above has a lot of nice mods, but
the combination of +2 skills and 20 fcr is the core of what makes
it valuable for a caster char and most of the rich people play
casters in 1.10.
> rare circlet
> +2 paladin skills
> 7% ml
> +7 str
> 11 res all
> - no bids
Above is not as good as a Harley/Shako for Hammerdin or FoH
and not as good as Guillaumes for a standard zealot. It
*might* be valuable to a Tesladin if you find one to trade
with.
> rare diadem
> +2 pala skills
> 7% ml
> 5% ll
> 38% lightning res
> - no bids
This one is better but same comments as above.
> rare diadem
> +2 amazon skills
> 7% ll
> +12 str
> 12% poison res
> damage reduced by 3
> 2 sockets
> - valued a PUL
Makes sense. Shako is about a Pul and this one is comparable
for a Zon - better for leech and damage or resists (using the
extra socket) but not giving life, mana, or MF. Socket quest
itself is valued about Lem in SC - not sure about HC. So
I think it should be about Pul+Lem considering that, but
of course it is a little harder to find a buyer (on Zon
needing resists or leech or strength).
> rare diadem
> +2 pala skills
> +7 dex
> +81 mana
> 17 res all
> - no bids
Mainly good for a poor Hammerdin, so I wouldn't expect much.
You should not have expected any of the above to have trade value
close to the one you originally listed, which I repeat, was worth
a fortune.
> [snip]
>>>get it though...
Hmm, maybe i just didn't try hard enough when i had diadems with fcr or
frw, but maybe i get that again next time i collected some more pskulls.
> [snip]
It's seems like the only place in the game i never been in luck is
runefinding, but i keep continue trying and hoping for the best :)
Same on you.
Do you also offer to wash a bald mans hair?
>>to me 😉
WOW, i gotten a eld one time from a pindle buddy, i really feel special
now 🙁
Sonni
Manual? What manual? This is UNIX!
In article <4277d1b4$0$217$edfadb0f@dread11.news.tele.dk>,
It all depends on the other mods, but a plain +2 <caster> skills
circlet-alike thing with 20FCR in itself is already worth something. If it
has added res-all, str, dex, mana, life or whatever, it's value starts to
rise rapidly... 😉
Not even with Hell Hellforges?
>Same on you.
Is this some kind of Swedish expression? :) In that case, I have a bridge
to sell you. 😉
>now 🙁
Sorry! :)
Patrick.
> rise rapidly... 😉
See my reply to last2know, i think that explain a little way even with
those mods in not worth that much on hcl.
Sure i had a great edeal of luck with hell hf.
So far i think i got 2 GUL's, 2 IST's, 2 MAL's, 1 or 2 UM.
That doesn't look that bad, but what about the 10 or 12 HEL's i got
there too, and then the 10 to 12 runes between IO and LEM, yep that
right not even a PUL from hell hf i gotten them from nm hf.
The sad look on my rune mule before i upped some unique armors showed 6
LUM's, 7KO's 6 FAL's and 4 LEM's, not the impresive runemule i've seen :)
>>Same on you.
> to sell you. 😉
No like i little rewrite of a danish saying, but i can't remember what
the thing you use in the hair is called in english :)
I think Denmark have quite enough bridges atm :)
>>now 🙁
> Sorry! :)
Don't be, i just did 5 pindleruns and i got an ort :)
i'm on a winning strike now :)
Sonni
No! I said Unix expert, not Eunuch expert....
In article <4277ecbb$0$246$edfadb0f@dread11.news.tele.dk>,
>> rise rapidly... 😉
Apperently, and interesting to observe; the HC and SC trade-values seem to
differ quite a lot...
Shampoo? :)
Hmmm, ok, how about some sand then? :)
>> Sorry! :)
Sounds good!
Regards,
Patrick.
