Okay so this is my first build, I've done some research think I have found most of the parts and have decided to build it myself rather then use cyberpower or anything like that to be more familiar with the computer in case something goes wrong. anyway the only thing im not sure on is the MOBO which i think I might be spending a bit too much on. also I might be interested in getting a second graphics card later on.
Case: NZXT phantom
PSU: corsair 750 w
graphics: sapphire AMD 7850
CPU: intel I5-3570K
HDD: seagate 1tb 7200 rpm
MOBO: asus sabertooth z77
Ram: 8gb corsair vengeance
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146073]
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010]
Graphics:http://www.newegg.com/Product/Product.aspx?Item=N82E16814102984]
CPU:http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504]
HDD:http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840]
Ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144]
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821]
I just want to make sure everything is compatible. If possible I would like to get the build closer to $1000 and I know the first thing most people will look to cut costs on is the case, But I am fairly fond of the case and I think the space and simple setup will be good since this is my first build. So if there is anywhere I am overspending or any parts that are overkill please let me know. Any help is greatly appreciated =)
Case: NZXT phantom
PSU: corsair 750 w
CPU: intel I5-3570K
