First Build!!! Don't know what components to choose!
petermai6655
4
I am trying to build my first desktop PC. Right now, I am trying to get the components sorted out.
I need a PC that can multitask, deal with video editing, photo editing, video encoding, and video burning. I also needs a PC that will still run smoothly when there are a lot of software installed on it (as I tend to install a lot of software on my computer and then not uninstall them even if I don't need them). I would like my computer to run Adobe software well and I don't plan to play games on this computer. I need advice on what components I should pick because I'm having a difficult time deciding what fit my needs. I want to have a computer that is reliable, easy to install, and durable yet fits my budget. ($400-500 including the monitor, keyboard, mouse, and other accessories.)
I did little research and I came up with this list.
http://pcpartpicker.com/p/KnZsNG
The only problem with this list is that I am worried that the AMD FM-8350 is not fit for my needs or is too powerful. I am also worried about the parts not working well with each other. That is that the motherboard that I selected will limit the power and capabilities of the CPU.
I would like some advice on what components to chose. Do you think the AMD FX-8350 is to powerful. Are any components bottlenecking? Or do you think I should build a Intel system...
(And no I am not planning to overclock.)
Do you think I should go with the AMD FX-6300 instead and go with the 970 chipset?
PCPartPicker part list: http://pcpartpicker.com/p/Vxsyzy
Price breakdown by merchant: http://pcpartpicker.com/p/Vxsyzy/by_merchant/
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor ($109.99 @ Micro Center)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard ($65.98 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($39.49 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.88 @ OutletPC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($27.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer ($19.89 @ OutletPC)
Other: Sentey® Gs-6008 Plus Stealth Gaming Computer Case ($45.99)
Total: $359.21
Generated by PCPartPicker 2015-08-23 01:38 EDT-0400
on your build the older 8000 nvidia gpu is real real old. those card are power eaters and run real hot. for the money your better off using a newer 500-700 line of gpu. on my build used the newer apu that has a better gpu built into a 4 core cpu.
PCPartPicker part list: http://pcpartpicker.com/p/VmD6zy
Price breakdown by merchant: http://pcpartpicker.com/p/VmD6zy/by_merchant/
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor ($99.99 @ Micro Center)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard ($81.99 @ NCIX US)
Video Card: MSI GeForce GT 740 2GB Video Card ($48.99 @ Newegg)
Total: $414.21
Generated by PCPartPicker 2015-08-23 01:44 EDT-0400
is going to be faster then the 6300 cpu.
So do you think I should go with an apu instead.
