First build help. (Non-gamer)
BaSiCEvil
12
Been checking the forum out for a few days now and after reading tons of information, I would like some opinions on what I am thinking for my first build.
I am not a gamer, but would like a system that could do some basic gaming if I decided to get into it in the near future.
This build will be a general use machine for web surfing, light video and photo editing and some MS Office work.
I need something that will be robust and give me at least 5 years.
Here goes:
APPROXIMATE PURCHASE DATE: 2 Weeks
BUDGET RANGE: $1,000 - $1,200
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: light video and photo editing, MS Office, Web Surfing, Research Gaming
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg, tigerdirect, amazon
PARTS PREFERENCES: None
OVERCLOCKING: Maybe as I learn a little more
SLI OR CROSSFIRE: Maybe, if necessary down the road.
Rosewill Blackbone Black Steel ATX Mid Tower Computer Case
MSI NF980-G65 AM3 NVIDIA nForce 980a SLI HDMI ATX AMD Motherboard
Thermaltake TR2 TRX-750M 750W ATX 12V v2.3/EPS 12V v2.91 80 PLUS Certified Modular Active PFC Power Supply
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Model HDZ965FBGMBOX
Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler
OCZ AMB Black Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Intel X25-M Mainstream SSDSA2MH080G2R5 2.5" 80GB SATA II MLC Internal Solid State Drive
(2) Samsung Spinpoint F3 HD103SJ 1TB 7200RPM SATA 3.0Gb/s 3.5" Internal Hard Drive RAID 0
Lite-on 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
Lite-on Black 4X Bluray Reader SATA Model iHOS104-06 - OEM
Microsoft Windows 7 Home Premium 64-bit
What says you? Am I overbuilt for my needs?
cory1234
628
11
Stay away from Roswell.
Get a better motherboard and get a cheap graphics card.
I would reallly go with an i5 750 build instead. The only reason I would go AMD is if I was going to get a 1055T or 1090T.
Get a better known psu, and you only need 400-500w.
The cpu heatsink you selected isn't that good. The CM hyper 212+ performs well and only costs $30 shipped.
+1 for that Intel SSD
Whoa some strange calls u made:
1. Non gaming build and 3-way SLI board :p Get the 880G with SATA 6GB/s and USB 3.0
2. Understand u want to have some room in case discrete but 750W a bit over hehe
3. I'd rather go with the new Sandforce based SSD
4. For about $938 AR
BaSiCEvil
12
Just thought of something that I forgot that may change some earlier suggestions.
In our new apartment, our 42" Plasma TV is about 8 feet away from the computer desk and I would like the ability to play movies from the computer to the plasma via HDMI.
While we are watching movies on the plasma, I would still like to have the ability to use the computer.
A friend suggested that I need a video card with "dual" cababilities.
Can someone comment on this?
Thanks.
BaSiCEvil
12
Decided to go in a completely different direction with this...
After HP pissing me off and telling me that they will not sell to the Bahamas from their website, I decided to go the i5 route based off what I had spec'd out from them.
I need suggestions on Memory. I'm thinking 8GB.
Tell me what you think...
COOLER MASTER Gladiator 600 RC-600-KKN1-GP Black SECC Body ; Mesh Front bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119206
ASUS P7H55-M PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131623
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
CORSAIR CMPSU-450VX 450W ATX12V V2.2 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102874
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
LITE-ON Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal 4X Blu-ray Reader Model iHOS104-06 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106325
LITE-ON Black 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Rosewill RCR-IC002 74-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223109
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758
I think that covers it all, except for RAM. Help a brother out, by recommending some memory. :D
You don't need the i5 for "light video and photo editing, MS Office, Web Surfing, Research Gaming", you should get a cheaper CPU and a better video card.
You don't need the CD/DVD-ROM if you buy a CD/DVD burner.
GIGABYTE GA-785GMT-USB3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128432
AMD Phenom II X4 945 + Antec Mini P180 White Steel MicroATX Mini Tower
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.410669
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231189
SAMSUNG 24X DVD+R 8X DVD+RW
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151216
SAPPHIRE Vapor-X 100284VXL Radeon HD 5750
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102865
Scythe SCSK-1100 100mm Shuriken Rev. B
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185097
SeaSonic S12II 430B 430W ATX12V V2.3/EPS12V 80 PLUS BRONZE
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151074
$854.90
BaSiCEvil
12
I forgot to put in my last post that I added to my needs for this system.
Seeing that my entertainment center with 42" plasma is less than 6 feet away from my computer desk, I decided that I would also use the new build as a media PC and send HD content to the Plasma as a seperate monitor, thus the need for a GPU that could handle both at the same time.
Does that change any of your recommendations?
BaSiCEvil
12
Looking for critiques on my final decision...
http://www.newegg.com/Product/Prod [...] 6811119206
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
http://www.newegg.com/Product/Prod [...] 6817139003
http://www.newegg.com/Product/Prod [...] 6814102874
http://www.newegg.com/Product/Prod [...] 6822152185
http://www.newegg.com/Product/Prod [...] 6827106325
http://www.newegg.com/Product/Prod [...] 6827106289
http://www.newegg.com/Product/Prod [...] 6820223109
http://www.newegg.com/Product/Prod [...] 6832116758
I am planning on pulling the trigger in about an hour or so.
Think that this will last me the long haul?
Similar threads
