[SOLVED] First Build. Looking for Advice.
Apr 24, 2020
Hey guys.
For the past 20-or-so years I've been a die-hard console player and I'm looking to make the leap to PC gaming. I compiled a list on PC Parts Picker and was just wondering if I could get your two cents. I was leaning towards Intel but I have had others recommend AMD.
The list can be found here: https://uk.pcpartpicker.com/list/8mDRyk
I'll likely be using it for playing Destiny 2, the Dark Souls Trilogy, Call of Duty, Apex Legends, etc, with a touch of streaming on the side.
I'd appreciate any feedback you may have.
Thanks.
